Question about HP LaserJet 3055 All-In-One Printer
Wireless router I have installed my HP 3055 though my wireless router. it is supporting for printing only, pl. let me know how to connect scan and fax through wireless connection.
    Genius:
  • 3,587 Answers
Hmmm..that's a bit different print servers usually only handle the print driver..check with your router folks to see if that's not the case. HP only sends what is available. The router is in charge of what gets through.
Posted on Mar 10, 2008
Connecting Hp wireless printer to my Acer 210 tablet
A wireless printer must connect to the wireless router so you must know the SSID & password of your wireless router.
Initial setup must be done fist by connecting and loading the drivers to the PC. Once done you can print wirelessly because you are printing to a networked TCPIP port.
Apr 12, 2013 | HP Photosmart 5514 Wireless e-All-in-One...
My home HP laser jet 3055 machine is not connecting
Hi:
Make sure that it is set to Auto Receive not Manual Receive. Also make sure the the telephone line cord is plugged into the Line jack not the Tel jack on the back of the fax machine.
Jul 19, 2012 | HP Deskjet 3050 Wireless All-in-One Inkjet...
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
How to connect the printer wireless
I don't think the HP 3055 has built in wireless capabilities. It does however have a built in 10/100 Base-T TCP/IP networking with 1 RJ-45 port, Hi-Speed USB 2.0 port, RJ-11 fax port, RJ-11 line-out telephone port. You should be able to connect directly into your hub or router and access the printer through a wireless router. You can get more information on set up at the link below.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/18972-18972-3328064-12004-3328082-1161389.html
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
172 people viewed this question
Ben Johnson
