Question about Acer Aspire 5100 Notebook
Waiting how do i get back to you
  • mrplayer163 Mar 10, 2008
    2687 9789 7674
    Genius:
  • 3,587 Answers
Answer the email, with your code from crossloop again..then wait 1 min..and connect. I sent you my code..from inbusiness4good@yahoo.com
Posted on Mar 10, 2008
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Hi, my router won't le tme connect to the internet. I have unplugged it, waited a few minutes and then plugged it back in. Re-booted it, and still no connections. Any suggestions?
you probably need to unplug power on your router too.
Unplug both power plugs and wait 20 seconds. Then plug back power to your MODEM FIRST.
Wait 1 minute to make sure the connection get an ip address.
After that, put the power back to your router.
Wait 20 seconds and try the connection with your computer.
If it doesn't work, restart your computer.
Hope this helps!
Feb 21, 2011 | D-Link DIR601 WirelessN 150 Home Router...
This morning when I attempted to start my 2006 Hummer H3, nothing happened. I thought I may have a dead battery but the lights and radio work fine. I then noticed the Passlock security lock light was on...
Hello:Try this procedure: turn key on, turn to start, let key come back to on wait ten minutes, turn key off wait 10 seconds turn key back on wait 10 minutes. turn key off wait 10 seconds turn key back on wait 10 minutes turn key off wait 10 seconds NOW try and start. In addition you might try tapping on switch assembly while trying to start. There is not any way to disable passlock. You might try having the engine control system codes read
Feb 01, 2011 | 2006 Hummer H3
My color ink cartridge dont print i always have problems with my color when i put it in y dont it print it is a new cartridge?
You could try to remove both of your ink cartridges.
Turn printer off and wait at least a minute.
Turn printer back on and wait until printer recycle.
Printer will indicated no cartridge installed.
Turn printer off again and wait at least a minute.
Turn printer on and wait until printer indicated no cartridge.
Install back both cartridges.
Jan 23, 2011 | Lexmark X2250 All-In-One InkJet Printer
All of my sensors work when tested, but they are not activated (when the alarm is on, they don't alarm when tripped). They have all worked in the past. How do I turn them back on? (I tried deleting them...
wait two min before setting them off them leave themopen for a min and wait tillsiren blows
,oh make sure its in away mode then open a entry exit door then close it back and wait till exit delay runs out (2 min)and trip sensors and wait for siren to blow
Nov 20, 2010 | GE Security Simon 3 Wireless Home Security...
I Don't see USB Device in "My Computer"
There are a few common causes of this problem.
1. Bad cabling, try a new cable and see if it shows up.
2. Bad drivers on your PC, try the device on a different PC, if it shows up, report back and we'll diagnose the PC. If it doesn't move on to # 3
3. Failed USB circuitry within the enclosure, buy a new enclosure, move the drive into the new enclosure and try again.
4. Failed drive within the enclosure. In this case you will need to either send it to a pro or work through several Do It Yourself methods to attempt a recovery.
If you wish the help of a pro, reply back with your Country, State and City and I will refer you to an appropriate facility. If you wish to continue trying to recover the data yourself let me know and we can step through several ways of attempting a recovery.
Hope this helps FixYa,
Crankstart
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif close.gif
Feb 23, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
After moving my fridge how long should I wait
Give your fridge at least 6-8 hours for the oil to run back into the compressor before turning it back on...
If in doubt longer is better...better to wait a few hours then wish that you had...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
I just brought home a DCR038W Danby compact refrigerator.
Yes, wait a whole day to let the compressor oil dran back to the compressor.
Sep 04, 2009 | Danby (DAR604BLS) Refrigerator
Has suddenly stopped connecting to internet on laptop. doesn't seem to get a signal or anything. main computer ok. seemed to stop after we had a thunder storm on thursday could this be something to do with...
Unplug your router. Unplug your modem. Wait 30 seconds. Plug your router back in and wait 30 seconds. Plug your modem back in and wait 30 seconds. Go to network connections under control panel. Right click on your network node. Enter enable. Wait a few moments and your network should come up.
Jul 11, 2009 | Belkin (F5D7633UK4A) Wireless Router
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Acer Aspire 5100 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
