Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door Hinge Replacement
I have sourced a new door hinge and last night removed exisisting hinge as the top lug had sheared. In doing so, the backing plate has fallen down into the bottom of the machine on the inside.
Can I reach this plate if I access the machine from the rear, or will I have to remove the front panel?
  • 105 Answers
Remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Posted on Mar 15, 2008
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
How do I replace the long screw that holds the door up on the door hinges,on a '97 gmc Sonoma?
I have done a 100 of these.
The hardest part is going to be to reinstall the spring on the lower hinge arm. this is not a screw but rather a pin.
There are two hinges that hold the door to body.
when the upper and lower pins are removed the door will come away from body, it is important that before you remove the pins you take a look at the hinges.
Pay close att. to the way the hinges sit inside each other and the way the pins go in. see if they go from top to bottom or from bottom to top. also note where the copper bushings sit in hinges. each hinge has one pin and two copper bushings top go into hinge.
Over time the pins and bushings wear out ,making door hard to open and close. When the pins and bushings get so bad that the bushing is worn out and then the pins are now wearing into the hinge hole itself then this get tricky. if hinge hole is egg shaped the new bushings will not last. the door will hang again in a few weeks. this is where is get costly, the hinges now need replacing. i have gotten good at welding the holes and filing them back to shape but this takes skill or hole will be wrong and bushing will not fit or line up.
Here is a youtube video to help you.
Take note. put jack stands under door with cloth to avoid scratching door.this is to hold door when pins are removed. have somone help you, they will hold door on stands. the wires will still run through door, pull door away from body a little to allow room to work.remove the spring, it will fall out as you remove pins, remove old bushings, clean hinge area and holes,next install new bushings, apply lube to holes for pins and on bushings, slide door back on frame hinges and install pins, next slide lock washers on pins to hold pins. last is the spring. you will need a spring tool, you may rent one at auto parts store. hope this helps good day.
Feb 26, 2012 | 1997 GMC Sonoma
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
Oct 05, 2009 | Smeg FAB28
How do i replace the gasket on a top freezer refrigator?
Hi, first you will have to remove top freezer door, remove plastic cover from hinge, at left or right, above door, remove top hinge, tilt door slightly forward and lift off, be careful with spacers between door and hinge, you have to put back spacer between door and hinge to get proper alignment. put door on flat surface, lift rubber and check underneat, you will see screws or plastic clips, if there's screw, make like 3 or 4 turns with screwdriver, dont completely remove screw, if you don't have, don't know what type of ref. you got, remove old door gasket, replace new one, and put it back on. good luck.
Aug 07, 2009 | Refrigerators
R/H door swings open too easily and hits counter behind door.
Hi LC,
Your fresh food lower door hinge cam assembly has failed and needs to be replaced. Not a big deal to replace, really... but you have to remove the FF door to get to it. <---which is VERY simple to do. But first thing first, right? You'll obviously need the replacement part on hand prior to the repair, so the part number is WR02X10779. You can see what it looks like here (you could also order it here if you don't have a local appliance parts retailer).
OK, now that you have the cam assy., Empty out all the goodies that you have stored in the FF door shelves. Then using a sturdy step stool, remove the upper hinge cover. Below the cover, you'll find three more screws, remove them (just so you know ahead of time... after you remove the last of the 3 screws, the door is no longer "attached" to the frame, so hold on to the door while removing the last one, OK?). Now all ya have to do is lean the door forward (from the top) and lift it off of the lower hinge/cam assembly.
Now that the door is off, all that's left to do is remove the old cam assy., install the new one and rebuild everything! Easy Breezy! You'll be in and out of this job within 20-30 minutes.
Oh yeah... one other thing. When you replace the door and are putting the top hinge back on, put all 3 screws in but don't tighten them yet. You'll need to "level" the door and THEN tighten them. Just lift the fridge door handle 'til the top of the door is level with the Freezer door, tighten the screws while holding the door in this position, deal? Cool.
Hope this helps!
SG
May 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
KDRP407HSS oven door adjustment
I found a solution. Remove door (very simple procedure listed in Use and Care Guide). Make a shim and attach it to the end of the hinge arm (the part of the hinge protruding from the door that goes into the slot in the frame). I used metal shears and a coffee can and made a metal strip that I wrapped around the arm 3-4 times. Reinstall door and it should be tight at the top. (Unfortunately I suspect this fix will be temporary until the ill-designed hinge mechanism starts bending again.)
Nov 12, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Wd62 door hinge
yes u do have 2 split the door undo the screws and simply seperate the 2 halves and the 2 lugs that hold the hinge lift off get a small probe to push the broken lugs out of the fittings insert the new hinge put the 2 halves back 2gether screw the screws back up and remount the door 2 the cabinet jobs a gooden good luck
Sep 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
279 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
