Question about Kitchen Ranges
Finding side panels (decorator) for a S136 JennAir stove (p/n 701997)
I am in dire need for side panels (decorator) for a S136 JennAir stove (p/n 701997). I have called nearly every place listed on Google, but they ALL tell me that Maytag ** longer makes this part, thus it's ** longer available!
There must be a whole warehouse of these parts somewhere. rusting away. I can**t believe that every last one of them was turned into Toyotas! So, if someone has a lead to where I might find at least the right side panel, I'd be a happy camper! I'd prefer BLACK, but if someone has a white one, I'll paint it!!
Wont operate. vent working.
Posted on Mar 10, 2008
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
My (new to me) apt has an electric jennair stove top -no instruct
Try http://www.jennair.com/flash.cmd?/#/page/home
Click on cooktops.
I have looked, but cannot find your model number. Perhaps if you look, you may be more sucessful, they do have pics and descriptions.
Oct 15, 2009 | Kitchen Ranges
My jennair stove causes the circuit breaker trip when I turn it on. Do I need a Jennair technician or an electrician?
I am both Appliance Tech & Electrician call me and I will Help You, Were 24/7 Appliance Service (608)214-5632 or Toll-Free at !-815-656-4236 Thank You Daniel
Aug 23, 2009 | Kitchen Ranges
A friend gave us a jennair stove, the new stove has a four pin plug and our old stove had three. Can I change the plug on the stove or do I need to change the outlet in the house
Either works. Do what is easier. If you g with the 3 wire the white on the range has to be connected to the chassis as well as the terminal connector. Eric
Aug 10, 2009 | Jenn-Air JES9800BAS Electric Kitchen Range
Replacing electrical outlet for stove top burner cartridge
You need to remove the cartridge then all of the screws that are around the inside perimiter of the well. You may also need to remove the control panel via the screws securing the top trim and the bottom flange. The part numbers for the wires with contacts are as foloow: 71002326 blue wire, 71002604 brown wire, 74005845 violet wire and w10116778 yellow wire. They should retail at @ 7.-8$ each.
Apr 07, 2009 | Kitchen Ranges
Jennair stove door locked
there is a thermostat on rear of oven that has gone bad.Unplug unit remove back panel and you will find it there.You can also undo your locking mech. and put back togather to get door open.
Mar 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Jennair s136 drop in range
I have a Jenn-Air S136 and need instructions on how to clean the oven.  Can someone point us in the right direction?  Thank you.
Jan 19, 2008 | Ovens
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Locking mechanism for jennair
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Dec 24, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
