Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Color Fading on Zenith E44W46LCD
Our Zenith E44W46LCD tv is 4-5 years old. The light next to the green light (tv on) on the front panel has been changing from yellow to red for about the last 6-8 months. It has recently started to fade color (green hue-almost like watching black and white). What's wrong with it and is it something we can fix or is it better to replace the tv?
  • 1 more comment
  • grizzly69 Apr 12, 2008
    I have the same problem even after replacing the lamp with the same exact part that was in there. My screen is heavily green tinted. I wish I could fix this I only had the TV for 3 years.
  • Kenneth Ossi Apr 13, 2008
    That means the projection light bulb needs to be replaced. I haven't replaced mine yet but I am sure is an easy thing to do. My TV is doing the same thing with the lights on the front.
  • sboyd08 Sep 11, 2008
    How do you get the orange light to disappear after changing the lamp out?
I have this TV. Lamp indicator came on and freaked us out so we shut the TV off until we could find a reasonably priced bulb. I bought a lamp (bulb) from discount-merchant (best price!) and we changed it out...easy enough process, however the "change lamp indicator" orange light remains on and the TV now has a lovely yellow spot in the middle of it. After arguing with my husband that he didn't install the lamp correctly, I have read for the past two days MANY of the same issue with this specific TV. We've had it 5 years in August so I guess that is about the life of this TV and a big apology to the hubby. :)
Posted on Sep 02, 2008
Its not the lamp its the whole color engine. it will cost you $2,000 to get it repaired. thank god i have 4 year protection plan. Best Buy did repairer after one year of use then had to do it again after 3 years of use. so they gave me new tv.
Posted on Jun 03, 2008
You neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Posted on Mar 21, 2008
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
I changed the LCD lamp, but there is still a yellow haze.
The yellow haze is the result of the blue polarizer burnt-in, you will find it sitting in front of the dlp chip.
Mar 20, 2009 | Zenith E44W46LCD 44" Rear Projection...
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Samsung Tantus 119cm 100Hz Rear Projection Problem
i have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Oct 14, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Aug 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
348 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
