Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Pump how can you check the pump? water does Not spray out of the Hand tool.
  • Anonymous Mar 24, 2014
    hand tools won't spray water
Replace water pump on bissell 1699
Posted on May 09, 2010
    President:
  • 1,673 Answers
Check the bottom of the tank and make sure that the seal is on the valve and not sitting in the hole where the tanks sits. At the back, is the top and bottom tight together, or is there a gap, should be no gap. Is the mix valve **** turning easily or is it hanging up? Sometimes the flow indicator cap leaks air and needs to be replaced. To get to the pump, you have to take off the top cover. Look and see if any lines are pinched, if not, then replace the pump, also check the pump belt.
Posted on Mar 11, 2008
Why does carpet cleaner not spray out water through hand tools or floor unit
Can only think of 2 things - pump or clogged spray nozzles.
Regards.
Dennis
Aug 22, 2014 | Vacuums
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
Wont pump water
Take the water tank off, you should see 2 spraying nozzles. You need to get to these and clear them out with a needle or something. Did the trick for me.
Or could be the pump itself. Confirm this using the hand tool - if it sprays water then the pump is fine.
Sep 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
It won't spray water and then pick up
Could also be the pump. Check this by seeing if the hand tool sprays water.
Have a model 9200 that is not dispensing fluid,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Jul 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have a bissell 9400-E and it doesnt spray cleaning fluid from underneath the machine, the hand tool works. have trie purging the machine with hot water in fluid tank and continuously hollding button with...
This may be caused because the pump belt has stretched or broken or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime.
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
Nov 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell proheat 12 amp will not spray water on to the carpet,nor will the hand tools spray water?
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Feb 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Unit is not pumping water out
This is most commonly caused by the rubber belt being broken, as the belt powers the main pump.
Check the belt, (through the access door on the side of the machine,) and if it appears worn or stretched, (or is broken or absent,) replace it.
Otherwise it could be a problem with the pump, or could be soap clogging the main water lines. Try flushing the water lines out with warm water. A good way to see if this is the problem is to try using the hand tool. If the hand tool sprays water, the problem is most likely not the pump. If it doesn't, it is probably pump-related.
-R
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Clear won't spray from floor nozzels but it does stray from hand cleaner
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
Apr 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
182 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
