Question about ASUS K8S-MX Motherboard
Asus K8S-MS boot problem..
Hi.. this is karthik.. i am using Asus K8S-MS mother board.I have tried to reboot my 80GB sata hard disk. 1st i have copied the RAID file to the floppy drive from mother board cd. then i have started to boot.1st i used f-6 key for 3rd party drivers for RAID then it successfully loads the files from cd rom (bootable xp cd). After completing the formatting of c drive, it says "Cannot copy the file : sysraid.sys". so what could be the problem. Does any one know the answer pls help me.
  • carthik Mar 10, 2008
    hi terry,
    my hard drive is plugged into the first sata slot only. then if i didnt load the raid drive, it says "** hard disk found to boot". pls help me
    sorry it says "** hard disk found to boot"
    Sergeant:
  • 349 Answers
My understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
Posted on Mar 10, 2008
  • terry Mar 10, 2008
    in this case you need to go into the bios and select your hard drive as the first one to boot (boot order)some bios have boot sequence also ,so check that out also,this info should be in the mobo manual,if you don't have it search it out on the net at asus web site
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Formating HD
Download " Hirens Boot CD " it has a lot of partitioning tools on it try one to check and set hard drive into partitions
Aug 18, 2008 | ASUS K8S-MX Motherboard
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
ASUS K8S-MX Motherboard Logo
391 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
