Because they handle two kinds of media, combination drives essentially have two optical pickup assemblies in one package. CDs and DVDs both look the same, but they need different laser light wavelengths to read and write them. It's not uncommon for a drive to go bad the way you're describing, where one kind of disc begins not working while the other kind is unaffected.
An optical assembly is two parts: the laser to generate the light for reading and writing, and a sensor to pick up the light that is reflected for reading. Over time the laser power drops, and there's not enough light for the disc to be read reliably or, as in your case, to even detect the disc. Since you say you've burned numerous CDs, you've put more wear on the CD side, so it's probably just worn out.
There are internal adjustments to tweak the laser power and information is out on the Web about how to squeeze a little more life out of the drive. But the cost of a new combo drive is so low now that there's no reason not to simply replace one when it fails. TigerDirect is one company I buy lots of parts from, and they have two drives that are just $20:
this one if your current drive is a SATA type (narrow data cable), or
this one if your old drive is an IDE drive (a wide 40-pin data cable). I'm just using those for examples, since there are many other sources.
Another option is to get an external USB burner, and then you'd have a drive you could use on different computers if you wanted, and you wouldn't have to go through the effort of replacing an internal drive (although it's not difficult).
cd or dvd +rw Faulty.if you burning with multissation way.if not,burn with multissatation way.
