Question about Optoma EP716 Multimedia Projector
Power problem I have an optoma ep716 and it doesn't power up. Looks like the lamp is fine. I can't find any burn marks on the board. The ballast looks ok but I don't know for sure. Does anybody think the problem might be the power supply. Maybe a voltage regulator? Has anybody else ran into this problem?
  • 2 more comments
  • BobSmalley Mar 10, 2008
    Yeah I don't see a glass fuse. I found a funny looking fuse almost looks like a cap I guess thats why I missed it. ** continuity. Don't I feel like a dummy.
    Thanks,
  • BobSmalley Mar 14, 2008
    Does anybody know of a cross refrence for part number STK392-010 it's a 3 channel convergence chip for a 47" samsung DLP television?
  • BobSmalley Mar 20, 2008
    Thanks for your help Tampa!
  • John Jones May 23, 2008
    I am having the same problem with no power but I am not as handy with electronics. I can't find the fuse. Can someone tell me where to find it and how to replace it? Any help would be appreciated,
    John Jones
    President:
  • 778 Answers
Hello BobSmalley,
From your post, I gather that you know your way around electronics. So, why don't you use a VOM (Volt Ohm Meter) to trace power starting at the PS and see where you lose it. You may find a blown fuse along the way as you didn't mention fuse status (and that projector surely has one). If you do have access to a meter you could also check the ballast to see if it's putting out enough voltage for the lamp. But since you stat that it doesn't power up at all, I would lean towards the Power Supply (PS) and locating the fuse (could be an AGC, etc... or a printed circuit fuse soldered in circuit right on the component side of the board near the edge where power comes in).
Keep us posted, and Good Luck.
Posted on Mar 10, 2008
  • Frank  Fernandez
    Frank Fernandez Mar 11, 2008
    I'm glad you found the open in the circuit. :)
  • Frank  Fernandez
    Frank Fernandez Mar 19, 2008
    I appreciate your thanks, but would more so appreciate a rating?
Power on, fan runs, get a red led at the "lamp" indicator then the projector goes to standby and shuts off. Projector is a benq MP515
Hi
Check the lamp physically if looks ok then problem suspect with Lamp ballast or lamp
ANS BY
M.R. Mumbai & Dubai
Sep 01, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use a screwdriver to remove the screw from the cover.
  5. Push up and remove the cover.
  6. Remove the 2 screws from the lamp module.
  7. Pull out the lamp module.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
Replaced a bulb and the red lamp light still comes on and the projector turns off
colorwheel or ballast need replacing. when you turn it on, listen for a high-pitched whir. if you hear it, the ballast is bad. if you don't, replace the colorwheel.
Oct 30, 2009 | Optoma EP716 Multimedia Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma hd65 wont power on
The problem sounds like the lamp ballast is bad--it's a circuit that initially starts the lamp and then keeps it burning--the lamps are like a welder's arc inside of a glass globe. When you push the power button, the ballast uses a spark of electricity (sort of like a spark plug) to get the initial arc going and then switches to low voltage, but HIGH amps to keep it going.---Rick
Sep 06, 2009 | Optoma HD65 DLP Projector
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Optoma ep1690 projector lamp won't come on. Machine starts, fan starts but no lamp. only has about 100hrs used life. Lamp looks perfectly fine but LAMP inicator comes on then goes off. Should I buy a...
reset the lamp timer. if you don't hear a high-pitched whir when you turn it on, the colorwheel is bad. could also be the ballast. worst case, the main board. if it is under warranty, send it in.
Aug 19, 2009 | Office Equipment & Supplies
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
325 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
