Question about Xerox Phaser 7750DN Laser Printer
Xerox 7750 Hi there, I read that you used to run gloss stock on a Xerox 7750 printer. Could i ask if you ever had problems with roller marks (we get a roller strip indent that can be seen when held at an angle to the light)? We are using Xerox Colortech 170gsm semi-gloss stock. In addition, we also get a grey haze in none toner areas (using the heavy weight and photo setting). Any advise you could give is appreciated. Thanks and regards, Matt
  • Matty J Mar 12, 2008
    Thanks for your response.
    It doesn't appear to be the fuser. I have also checked the imaging units and transfer roller - all fairly new and no problems.
    I am printing from Tray 1 (MPT) and the marks appear as bands across the page (a dull sheen when compared to other areas of toner - like the toner has been squashed). I thought the marks were coming from the rollers, but in measuring them they don't appear to line up to any of the rollers. In addition, there is sometimes black dirt marks appearing on the printed pages - which appears to be toner. I have changed the black toner cartridge, but this failed to help.
    The printer is three years old and has only done 23k prints. The Accumulator Belt has not been changed in this time, however they are rated at a life span of 80k prints. Do you think this could be at fault? - I have inspected it with a torch and it does appear to have some small toner particles attached and minor scratches. Is there a safe way to clean this part?
    Other consumables -
    Toner
    C - 17%
    M - 96%
    Y - 100%
    K - 100%
    Imaging units -
    C - 81%
    M - 100%
    Y - 85%
    K - 89%
    Transfer roller - 100%
    Belt cleaner - 100%
    Fuser - 76%
    Waste cartridge - okay.
    Thanks and regards,
    Matt
  • Matty J Mar 13, 2008
    Thanks again for all your help.
    I did some testing today and it looks like the black marks are coming from toner on the thin myler paper deflector near the tray one entry rollers (black marks appear before going into the fuser) - can this be cleaned?
    I have also changed the developer and cleaned the belt cleaner blade.
    Just a couple of further questions -
    1. Will the transfer belt still work okay if I clean it with iso. alcohol? I was previously told by Xerox to only gently wipe it with a clean tissue - if at all. It does have speckles of toner that look like they have been there for sometime (maybe creating the haze).
    2. I think you are correct that it is the small plastic rollers creating the marks. Will try different print settings tomorrow (slow it down and reduce the toner setting). Did you have this problem with gloss stock? If not, what stock did you use? It is odd that the machine is promoted as printing on gloss stock + I'm using Xerox media and still getting such poor results.
    Thanks again and regards,
    Matt
    President:
  • 2,072 Answers
In what direction is the mark? Is the defect a dent in the paper,that repeats or is it a crease in the direction of the paper feed? If it is a dent that is repeating, the cause would be the transfix roller. If it is in the direction of paper feed, there may not be much you can do, most of those ceases you can see when held sideways like that come from the rollers edges. Just the normal crease that can be created by the end of the roller.
You can open the covers on the machine and make sure there is no excessive buildup of ink on any of the rollers. It is possible there is to much pressure on one of them, but with certain types of paper, there may not be much you can do. I will research it more and get back with you on that issue.
One thing you can try, (because your marks can be comming from a defective fuser), set the machine to print 4 or 5 pages, then shut it off or unplug the printer in mid run. Carefully look at the jammed pages to and see where in the process the crease is comming from. Take note and let me know please.
The gray haze seems to also indicate a possible fuser issue, but moreso, it sounds like the black housing is over toned. Most likely cause of that is a bad housing or bad developer. The developer in that machine will become worn and need replacing. It will restore the contrast and should resolve background issues.
Posted on Mar 11, 2008
  • 1 more comment
  • Rick Kasper Mar 11, 2008
    I forgot to mention. Paper is very very rarely a problem with a print quality issue.
  • Rick Kasper Mar 12, 2008
    I was looking over this again. I dragged out a 7700 I have in back, its a 7750 with some software changes.
    I really think the background issue you have is the developer. Where you replace the drum unit, inside there is a housing, the developer is a finlely ground plastic coated steel that carries the toner from teh housing to the drum. I have seen the developer fail and cause that type of problem. Mainly you mentioning the black spotting makes me strongly suspect that.
    Also have you removed the belt cleaner and wiped off the blade. It is on the rignt end of that accumulator assembly held on with 2 torx screws. Remove it and clean with a dry cloth.
    Now as to your roller marks. I am certain after running the machine, that those are comming from those small plastic rollers on the fuser assembly, with the fuser in the machine they are on the top of the fuser, small solid black plastic rolls. That is comming from the image not being 100 percent cooled when they come out of the fuser assembly. I don't believe there is anything you can do to 100 percent eliminate that, other then trying a new fuser.
    The accumulator belt, also knows as the transfer belt, there is almost zero chance that is a problem. You can clean it with s soft cloth dampened with some alcohol. It cleans well, but no real reason to do that unless something is really stuck to that belt.
    I have had them run 200,000 images with no issues. Actually other than just worn out with stripes from the cleaner and just age, I have never had one of those belts cause an actual quality problem. They are exceptionaly reliable
  • Rick Kasper Mar 13, 2008
    Yes that mylar strip can be cleaned. Just take caution not to put any kinks in it.
    Yeah, that transfer belt cleans well. Just be sure you use a very clean soft cloth.
    I have had labels stick to those belts many times. First time I was aprehensive about cleaning it, but I have cleaned glue off of those many many times with excellent results. Just don't use a lot o pressure, let the alcohol do the work. You are using the cloth to just remove the residue and remaining alcohol. I have done that many times with good results, I am certainly not replacing those belts a almost $300 a belt for glue and toner stucl to them.
    Just be sure you let the alcohol dry before you run it. So its not wetting the cleaning blade.
    No I doubt it is the gloss stock. You may want to try setting the machine to plain paper settings to lower the fuser temperature during fusing. I suspect the lines are simply the fact, that that paper is heated to 360 degrees F to melt the ink into the paper, and with a different texture the ink is not totally set when it gets to those rollers and it is sort of giving it an "ironed" look.
    Not confident you can eliminate that 100 percent.
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
I am looking for parts list for a XEROX Phaser 7760 we got a service manual but no parts list need to find feed rollers and one way bearings for # 4 &5 trays ASAP any one able to help
600K78460 Roll Kit (3 Rolls/Kit) but they are the same as a 7750
the bearings don't have no number on the 7760 service manuel.
but you can check this manuel for the 7750 they should be the same.
http://www.office.xerox.com/userdoc/P7750/7750_Web/partslist/index.html
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Jun 01, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox 7750 issues
Did I not erspond to this ? Seems like i had but getting this question back. Let me know please.
Mar 12, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7750DN Laser Printer Logo
1,385 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
