Question about Refrigerators
Looking for spare parts for Fisher & Paykel refrigerator model number E440TRT. I need to replace the bottom shelf on the fridge door. Where can I order/buy the part?
  • Anonymous Dec 27, 2008
    i , anyone able to help ? I need the same thing for an e442b.
  • ssmith3104 Apr 18, 2009
    SAME PROBLEM. WE NEED A NEW DOOR SHELF FOR OUR FISHER & PAYKEL E442BRE REFRIGERATOR. OUR EXISTING ONE CRACKED WITH ABSOLUTLEY NORMAL USE WHEN 4 Y.O.
Glue it in place with some really good glue, better than it ever was.
Posted on Apr 20, 2010
WE NEED SPARE PARTS FOR PARKING TICKET SPITTER OF FEDERAL APD TD-300
Posted on Sep 11, 2008
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fisher paykel e224b fridge not cooling. everything working fine but fridge was originally pulled apart before i looked at it, need to know which thermistor is which (black and white ones in the freezer...
Kitchen Laundry Appliances Fisher Paykel US
Are you sure that is the part number. I went to the above link and could find nothing with a part number of E224B. Please look on your unit and verify there is no other numbers. If you find additional information please post it and we can attempt to help.
Semper Fi,
Z
Feb 01, 2018 | Fisher and Paykel Active Smart E522B...
E522BLMFD model refrigerator door alarm won't stop beeping. Fridge eventually turns itself off because it thinks the door is still open. How can we disable or replace the microswitch which presumable...
The door switch has 3 terminals and wires on it. Jumper the wire that does NOT turn on the light to the wire that is on C of the door switch. If you look at the switch it will have one wire distant from the other 2.... that wire is the power wire "C". You jumper that to the wire that would be attached to the "NO" terminal. After you jumper the wire... and TAPE IT with electrical tape the door alarm should be silenced and the internal light will NOT work until you replace the switch. Label the remaining wire with masking tape... NC and Actually label all 3 wires as you remove them... C, NC and NO. Just use write that on a strip of masking tape and then put it on like a horseshoe pennant.
You can order a switch from Fisher and Paykel AU. (See number below)
Phone Contact our spare parts team on 1300 650 585
If your not in AU the door switch is very common... call any LOCAL appliance parts source and they should have one.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I am looking for crisper bins for a F & P N500B fridge
Here is a parts store you can call 6 days a week and order any part you need I did not find that model listed but you can talk and find the number. here it is and hope this helps thanks for using fix-ya.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=E522B
Jan 24, 2010 | Fisher and Paykel Active Smart E522B...
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
Door shelf support broken
Hi Shari. Yes. Go to any hardware store, or a home depot or lowes. Go to the adhesives isle. What you need is an epoxy adhesive that will work on plastic. There are different ones that will work so read info on the containers to find the appropriate one. One I use a lot with success is called JD WELD.
May 03, 2009 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
