Televison & Video Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba just turns off
I have a dbl projection 44hm85 manufactured oct 2005 and it turns off what might be the problem
Anonymous
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Mar 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
12089
Points
132
When is the last time the bulb got replaced? This might be the culprit. I would check back on the time of replace and think about changing the bulb if its been more than 2200 hours. I think that is standard time for projection bulbs. Hope this helps!!
How to clear code f901 toshiba 456
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
How to reset cdfo error toshiba estudio 355se
service call
turned ON.
disconnected.
circuited.
I have a DLP rear projection TV that suddenly colors and now yellows oranges, greens greys, no longer bright color defiition? what do you think is the problem
It is not likely to be a cleaning issue but could be either a lamp reaching the end of its life (2,000 hrs/2 years) and the worst possible reason would be a problem with the optical light engine this model uses.
Someone would have to try another lamp and take it from there.
TOSHIBA DLP 44HM85 - When turn tv ON: Operation indicator flashing orange, turns red. System in STANDBY MODE. How can I get out of it and watch tv?
If you have never replaced the Lamp and the TV is over 2 yrs old,Then its Time you replaced The Lamp.
Mats Electronics had them on sale for $89.00
1-800-628-1118
1helpful
Broken outer screen on my toshiba progection
Manufacturer Toshiba Part Number 23311898 Description SCREEN FRESNEL 42H Manufacturer Toshiba Part Number 23311897 Description SCREEN LENT 42H81 Manufacturer Toshiba Part Number 23311863 Description SCREEN PROTECTOR
1helpful
I have a Toshiba DLP Tv 44HM85. It turns on but
the great news is you can do it. and its easy; even if you have to rebuild your lamp. If you can change a automobile headlight you will think its easier. bulbstock.com has your bulb for 125 bucks. here is your lamp part number 72782309
TV keeps shutting off
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
