Question about Brother HL 5140 Laser Printer
Fixing unit failure
The fixing unit failure of my Brother HL-5140 started after extracting a jammed page. Following the instructions in the manual has for a while restored the unit so I could print again a few pages until it fails again.  After taking the fixing unit out and cleaning a little build-up of dirt on the thermal sensor the unit worked again fine for a couple of weeks. Now the unit fails again after printing just one or two pages.  Should I replace the thermal sensor or the small circuit board it is connected to, if I can them? Where could I get them? The heating circuit must be intact because the printed output is fine when the printer works. Thanks for any advise.
    Genius:
  • 3,587 Answers
Actually, replace them both, since the sensor and board are integrated...besides you'll find that the new set works better than one new, one old.
you might want to check your drivers for currency here
Posted on Mar 10, 2008
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
HL-5140 paper jam
Perhaps look along the paper path for the little bit of paper that maybe stuck along the path somewhere. I had this problem and it was just a little piece of the corner of a page wedged in the back of the toner tray.
Dec 30, 2008 | Brother HL 5140 Laser Printer
Feeds two blank sheets then jams
Im pretty sure that the printer is broken... If you really want to spend twice as much on fixing your printer go ahead, but i sugest calling the company and asking for assistance they will probably send you a new 1 and then you just send them your odl 1 thats what i did..
Mar 06, 2008 | Brother HL 5140 Laser Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
811 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
