Question about HP PSC 750 All-In-One InkJet Printer
Carriage Jam Error from replacing refilled cartridge
Hello I get this Carriage Jam error everytime I replace the refilled cartridges on my printer, The first try that i replaced the cartridges, it would only print black, so I took them out to get the color back and then now i get Carriage Jam error. Please Help!
  • 1 more comment
  • Neilos Mar 14, 2008
    Hello again,
    I replaced the cartridges again and the black one works, but the color one still doesn't. Both were refilled. Could the roller still need to be cleaned/serviced or would it be something else?
  • Anonymous May 26, 2008
    mine just won't leave the jammed mode. It jammed once and that's it. No more printing
  • ravi singh
    ravi singh May 11, 2010
    hey i think ur roller of printer is not working properly.]
    so u should change that .then tell me ok......
  • 54 Answers
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Posted on Mar 10, 2008
I'm having a problem with a "carriage jam" error message. I've followed the instructions (several times even) per several other posts as well as general HP printing support. I've tried the steps...
It sounds like you service station assembly is damaged and will likely need to be replaced (cheaper to get a new printer though!)
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 22, 2013 | HP Photosmart C5280 Printer
Tip
Carriage Jam Error on HP Printer There is nothing much to do if you get a...
There is nothing much to do if you get a Carriage Jam error. We can give a try to solve it ( Usually carriage jam error results in Hardware failure )
Follow the instructions below to resolve Carriage Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges. Check for any paper pieces, if so, remove them.
  5. Move the carriage manually 5-6 times from left to right.The carriage should move freely. ( Do not apply force )
  6. If the Carriage does not move freely, try to remove the cartridges and close the rear and front access door.
  7. Power on the printer and it will prompt you for missing cartridges.
  8. Install the Cartridges.If it does not prompt you for cartridges missing, you will find Carriage Jam Error on the screen
  9. This indicates the printer is faulty and needs repair
In any condition if you are not able to fix the issue, Contact HP ( 1-800-474-6836 ) If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer
Regards,Ron
Please rate this solution if it resolved your problem
on May 20, 2011 | Office Equipment & Supplies
5100 ...................Carriage control error
Sorry, can't be solvable.. for e5 error.
If you refill your color cartridge that's what it happens.
For Canon, if you refill 4~5 times... (only apply to color), your cartirdge is not readable.
The only solution would be replace your cartridge with new one.
Apr 11, 2011 | Canon PIXMA iP1300 Printer
I recently aquired a HP psc 2410 all in one printer. Upon start up I got an error msg that the cartridges are jammed, unjam and press ok. Well there doesnt appear to be a jam. The cartridges slide back and...
There is little or no value in older printers.
However the unit has gots its positioning confused.
Try switching off and on printer several time, opening lid for cartridge change to see if it can synch itself again.
Please dont forget to vote if you liked my answer
thanks
Feb 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
I keep receiving an error message about the cartridges.
hello, i have found that refilled ink cartridges fail more than hp oem, and that mixing, refilled with hp oem, sometimes the refilled will cause a short, and point to the wrong cartridge as being deffective. though i have had the actuall carriage unit fail electronicly. but the simpliest thing to do would clean the electronics on the cartridge, as well as the contacts on the carraige unit, you will need isopropyl alcohol, and a soft paper towel. if that does not work, then i would recommend replace both ink cartridges with hp oem inks, not refills.
Oct 04, 2010 | HP PSC 1210 All-In-One InkJet Printer
Printer reads out "Carriage Jam". Have done all the usual stuff.... shut down,unplugged, cleaned around connections and still reads out "carriage jam". Makes a lot of noise after opening carriage and...
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hp Cartridge issue
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
Step one: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Figure 1: Lifting the top cover
Lift the top cover.
  1. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
2 - Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  1. Lightly moisten the swab and squeeze out excess moisture.
  2. Holding the cartridge by its handle, wipe the copper contacts.
Figure 4: Wiping the contacts
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
It is telling me cartridge error What does that mean
Did you just replace a cartridge. Sounds like you used the wrong one.
Oct 01, 2009 | HP Officejet 4215v All-in-One Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Pixma iP4200
You either have bought a bad cartridge, or are using a generic or refilled cartridge, or have damaged the contacts in the carriage assembly.
Replace the same cartridge again only make sure you use a new Canon cartridge. If this does not help, either the contacts in the carriage assembly are bad or the main board has bit the dust.
Repairing the contacts would require you to remove the upper case so you can access the contacts, remove the ink cartridge and streighten out the contacts before reinstallig the cartridge.
The contacts are located at the front of the carriage assembly under the ink cartridge.
Oct 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP PSC 750 All-In-One InkJet Printer Logo
138 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
