Question about Jetway 939GT4-SLI-G Motherboard
Will not boot into Bios
The motherboard will not boost past the debug code of C1. Well...it will but only twice so far out of the 30+ times I have tried. During the two times it did load, windows froze and I had to reboot. When I rebooted, it went back to doing the same thing. I don't know if this is a bios problem or what. Any help would be appreciated. Thanks!!!
  • 3 Answers
Hmmm... why dont you try to reinstall your OS...maybe there's something wrong with that..^ ^
Posted on Mar 10, 2008
Initialize POST Error Manager(PEM)
try clearing your cmos. (little battery on motherboard) or one of your memory modules might be bad. try one stick at a time or if you only have one stick, you may want to pick up a new one.
Mar 12, 2014 | Computers & Internet
Fujitsu siemens lifebook a1220 master bios password
1. Exit Windows or reboot to the native MS-DOS mode,
2. Using the "Command prompt only" option from the Windows Startup Menu (hold Shift and F5 at the same time while your PC boots).
a) At the C:\> prompt, type: DEBUG
b) Press <ENTER>.
c) You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
(which will show as -o 70 2e at the DEBUG prompt).
d) Press <ENTER> and then type:
o 71 ff
e) Press <ENTER> and finally type:
Q
f) Press <ENTER> one last time, to quit DEBUG, back to the C:\> prompt.
3. Now you're ready to reboot your PC
a) Press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup.
b) You'll notice that the password is gone. :)"
Feb 13, 2014 | Fujitsu Siemens AMILO Pro V2000 Notebook
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
Need to reset the password
Make A boot disk from a working Windows 98 machine. After you make the boot disk, copy the MS 'debug' to the floppy.
Boot the laptop from the floppy.(this might not be possible due to a setting in the BIOS.)
Search online for MS Debug +clear CMOS
Run the Debug program and type in the commands exactly as written.
reboot, and you should be able to go into the BIOS by holding F2.
That's it.
If you can't boot from the floppy, remove the hard drive. the computer should boot from the floppy, no matter what the BIOS setting is.
Nov 25, 2008 | Panasonic Toughbook CF-27 Notebook
C1 code, computer won't boot
get the battery out of the socket and reset CMOS by jumper after you unplung the pc's mai power supply
Oct 24, 2008 | Abit AB9 Pro Motherboard
Clear BIOS settings
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory. However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
Code: O 70 17
O 71 17
Quit PHOENIX BIOS
Code: O 70 FF
O 71 17
Quit GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
Code: O 70 2E
O 71 FF
Quit
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Jul 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
EliteGroup ECS AMD690GM-M2
get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that display...watch for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years waranty..am i right?)
UDIN (indonesia)
Jun 13, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
C1 led post code
try changing your RAM with new one
Nov 08, 2007 | EliteGroup ECS P4M800-M Socket...
Memory upgrade - P4M80-M4
Maybe your RAM is not compatible with the motherboard just refer to instruction manual...
Nov 06, 2007 | Biostar P4VMA-M Motherboard
Jetway 939GT4-SLI-G Motherboard Logo
133 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
