Question about Microwave Ovens
Unreadable display on LG MS-2384BL Microwave Oven
  • Anonymous Dec 20, 2008
    display blank and unreadable
  • pulsev2 Aug 12, 2016
    display or keypad?
  • Microwave Ovens Master
  • 6,694 Answers
If you wish to get some details about microwave oven repair then check the following link
http://electro-medical.blogspot.com/
Posted on Aug 18, 2016
milten1
  • 1304 Answers
SOURCE: What would cause the control
sorry i lost my connection
i am tracking down your part and will provide you with the part number as quickly as i can
i want to make sure i find you the cheap[est in cost as well
thank you
'again im sorry i got disconnected
Posted on Nov 01, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: paint inside microwave oven, Can it be repainted ?
Yes. You need to clean it, sand it shiny, then clean it squeky again.
Then you can get high temperature appliance paint in spray on brush-on form from local appliance part store or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: change of lamp in LG microwave oven MS-194A
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
ginko
  • 19396 Answers
SOURCE: Microwave Does Not Heat.
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
fieldy14
  • 456 Answers
SOURCE: LG microwave oven rotating but not heating
I have found that the common cause for this problem is either the 'High Voltage Fuse (HV fuse)' or the 'Magnatron Assembly'. In some instances it can easily be both.
My advice is to read throughly how to discharge a 'High Voltage Capacitor (HV capacitor)' to avoid any injury or worse yet, death.
After doing so you can find the HV fuse runing from the HV capacitor, it will be inside a small plastic casing, you will be able to see with the naked eye if it has blown. If so, replace it.
As for the magnatron Assembly, it looks like a large silver cube with a series of magnets inside it, they are not as easy to test to see if they are faulty or not so if the fuse doesnt repair the issue, replace the magnatron assembly as well. I hope this offers some help. Good luck.
Posted on Mar 21, 2010
What is wrong with our LG microwave oven ms 5646 it gets electricity, but it still doesnt go on?
Check the main fuse for continuity - inside the cabinet, near where the power cord enters. Stay away from all high voltage components as they can carry a charge of 4000 volts, or more, even when the oven is not operating.
May 10, 2014 | Microwave Ovens
LG microwave oven Ms-1927c is not heating up. only buzzing sound can be heard.
That would likely be a shorted high voltage diode or failed magnetron.
Replacing the high voltage diode would be economical, but on most counter top ovens, replacing the magnetron would likely not be.
But the service manual is here: http://elektrotanya.com/lg_ms1927c.pdf/download.html
Here are a a couple of good help links:
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
You can order LG parts from Encompass here but since the service manual does not have part numbers, it would probably be best to call Encompass toll-free at 866-779-5835.
Aug 24, 2013 | LG LMV1630ST Microwave Oven
I need a manual book for the LG Wavedome microwave
Hello, ideally we need the exact model number of your Oven however the following is a link to the LG website where you can download a manual for a WAVEDOME
http://www.lg.com/us/support-product/lg-MS-152XC
Jul 30, 2012 | LG MC7849HS Microwave Oven
LG MS-1943ALT Micowave not working, light, fan and turntable all work, no heat
From the decription that you have provided, the magnetron is highly suspect and is the most expensive part to replace, cheaper to replace the microwave oven in the long run.
Sep 06, 2011 | LG Microwave Ovens
My microwave not starting
My microwave on top of stove oven,whirlpool gold. When i closed the door but it keep said"door"and won't start.
Jul 21, 2011 | LG MS-0744Y Microwave Oven
Microwave Oven LG MS-256EL/MS-257EL The oven does not work in microwave mode however the halogen and the fan assisted plus grill do work.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | LG Microwave Ovens
What size fuse is a 250v 10a drawing fuse inside my microwave would a 6.3 32mm fuse be ok.its a lg ms-283 mc microwave
Chances are it is a standard 1/4" x 1-1/4" (6.3mm x 32mm) but I would suggest measuring it to be sure.
Here's an exploded view of that oven to help in disassembly.
May 28, 2010 | LG LMV1650SW Microwave Oven
It's not getting heat and LCD looks like there's water inside.
On most Sharp Carousel Microwaves, the display stops working after time. As for the not getting any heat, the magnetron or the high voltage transformer may not be working.
Jul 04, 2009 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
206 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
