Question about iRiver Audio Players & Recorders
POwer switch doesn't work. I have an X20 iriver.
The problem was with the battery connectors which had retracted a bit when the battery was removed. I had to push them up a bit to get the battery to sit properly and for power to work.
Posted on Mar 11, 2008
Iriver plus 3 not recognising iriver x20 player
try to upload the songs onto it with windows media player 11 i only use iriver plus 3 for videos
when ur in windows media go into sync then it has like a side bar just drag the music into that and down the bottom of the bar it says sync press that
and if that doesnt work u might have to buy a new one
Aug 29, 2009 | iRiver X20 MP3 Player
I can't figure out how to put playlists on my iriver x20
yea i know what ur talking about. unfortunately the iriver x20 can only read SOME types of playlists. for example the windows media playlist that some people use doesnt work but the .m3u files which u can convert on winamp does work. its a real pain i know but that's why i just add files while i listen to them on the music menu of the x20.
hope that helps!
Feb 18, 2009 | iRiver X20 MP3 Player
IRiver X20 movie problem
yea the iriver x20 isn't very reliable when it comes to video files. there could be like 10 things wrong with the codec and even if u fix all of them it doesn't help. your best bet is to convert to wmv using the iriver program or another program like winavi converter. its really fustrating i know but its just how the iriver works.
Dec 18, 2008 | iRiver X20 MP3 Player
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
IRiver X20 Docking station
IRiver does not make a proprietary dock for this player; other manufacturers do not make them for IRiver because iRiver is a small player. You can take your IRiver into a Best Buy or other shop and test it in another company's dock, but it is not guaranteed to work. This is the only truthful answer I can give you.
Mar 17, 2008 | iRiver X20 MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Transferring recordings from iRiver x20 to PC
Yes, it should work if you connect to the pc then click on my computer> iriver> then find the recordings and copy and paste them to a folder on your computer.
Jan 05, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Iriver X20- playlists and videos
yeah, basically all i did was change my settings to MTP.
then i went into internal hardrive (just in normal usb mode)
i selected the songs i wanted and right-clicked (make sure to do this one one of the songs you selected) in the options that come up it should say "create playlist" (in bold) i clicked that, it wouldn't let me rename the playlist... but it worked fine... and now they come up in the right place, i didn't even use Iriver plus 3.
Nov 22, 2007 | iRiver X20 MP3 Player
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
1. Turn the player off - you may need to take the battery out to do this.
2. Hold the menu button in.
3. Still holding the menu button in, press the power button.
4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
5. Your internal memory will be formatted and you will now be able to start your X20.
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
