Question about HP PSC 1210 All-In-One InkJet Printer
Found New Hardware error message
I have installed the HP PSC 1210 all in one and everything is working propertly. The weird thing is, my computer has a found new hardware screen that comes up that tells me that there was a problem installing this hardware "HS PSC 1200 series". "An error occured during the installation of this device." "The system can**t find the file specified".
I downloaded the driver off the HP website. The message is a constant on my computer as ** matter if I click Finish on the found new hardware screen, it will re appear after it locates the new hardware again.
Like i mentioned before, the printer works just fine. Any suggestions.. I am operating Windows XP Prof 2002. Thanks!
    Sergeant:
    Champion:
  • 277 Answers
Configure the device manager, removed auknown device driver, then restart the cpu
Posted on Mar 10, 2008
    Genius:
  • 3,587 Answers
That can come from having two of them on the printer profile..open that to check if the computer is looking for two printers.
I just bought a used HP PSC 1210 All-In-One InkJet Printer from a computer recycle store and I can't install it on my Dell 2400 Dimension PC with Windows XP. This printer is not on the new hardware list...
Hi Good day!! You will need a cd to install it. if you don't have the cd you can download the driver here: http://www.hp.com/#Product go to Support and Drivers in step 1 click download and software step 2 enter your pinter product (PSC 1210) now click your printer driver, after that choose your Operating system and then you can now start downloading the driver.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 18, 2010 | HP PSC 1210 All-In-One InkJet Printer
Out of paper error when paper installed.
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=uk&lc=en&dlc=en&product=90764
Also please make sure that you are using the supported papers as per the following Hp web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00691&cc=uk&lc=en&dlc=en&product=90764
If the issue persists, please try with a diffrent set of paper and verify the result.
If the issue persists, repair your printer as this is a hardware issue.
:) Dr Tony
Apr 07, 2010 | HP PSC 1210 All-In-One InkJet Printer
My computer doesn't recognize that my printer is hooked up every since I unplugged it and moved it.. I don't have the manual and I know that there is a certain order in which things are pluged in.
To avoid errors, install the HP PSC software before you connect the HP PSC to your computer. If an error message appears and you clicked Next or OK, do the following:
1 Press Esc on your keyboard to exit.
2 Turn off your HP PSC.
3 Disconnect the HP PSC from your computer (detach the USB cable).
4 Follow the software installation steps outlined in the Setup Poster that came with your HP PSC.
If you receive a message that you have a previously installed version, you will not be able to finish installing the HP PSC software. You will have to uninstall the previously installed version in order to install the HP PSC software.
If your computer is unable to communicate with your HP PSC
If communication cannot be established between your computer and HP PSC (for example, the HP PSC status icon has the yellow error triangle), try the same tasks outlined under If Microsoft’s New Hardware Found message does not appear on page 57 of the manual.
Here is a link to the manual for your printer...
http://h10032.www1.hp.com/ctg/Manual/bpu05065.pdf
Jan 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
PSC 1210 ALL IN ONE WILL NOT CONNECT TO MY NEW DELL INSPIRON WITH WINDOWS 7 . IT SAYS THEREIS A COMPATABILITY ISSUE?
drivers are no available on website for win 7. wat you can do you can directly connect ur pritner to computer with usb cable you will se message found new hardware. installing device drivers. after some time it will show you message device is ready to use. then click on start. go to start search adn type pritners. then hit enter. it will open pritners windows.
in that window click on add a pritner on top. then select add a local pritner. then it will says select existing port select usb vertual pritner port and hit next. then under manufacturer select hewlett adn packard and under prtiner select psc 1200 series prtiner and hit next. do not share this pritner follow onscreen instruction to finish add a pritner wizard.
Dec 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP 1210 won't print. Printer online, but no print.
What do I do to get this printer installed? I have done everything that I can think of.
Nov 10, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 It says no scanner found ?
as the copier works its not a hardware concern.if the scanneris not found it means the drivers are not installed properly.Try uninstalling the drivers completely from the device manager as well as the printer and faxes and the scanners and cameras(if possible delete the ebtries in the registry as well that are related to the software and the VID and PID keys from there).Then try a plug and play.....see if it works....
Jun 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
Install hp psc 1210
lost my cd for my printer hp psc 1210 where can I download for free
Aug 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HPSC1610 all in one
hi i have a same problem regarding to hp 1210 all in one printer .scanner .copier what i will do so that i can scan picture tnnx for answering my question this is my yahoo messenger alfredo_torreliza2000@yahoo.com plz send your answer to this yahoo messenger
Jul 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
PC power resets w/ HP PSC 1210 plugged in
one of these updates causes a conflict more than likely a microsoft hotfix, try using a different usb port and unplug and plug printer back in
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
