Question about Hoover F5515 Hot Spot Upright Vacuum
Hi it sucks at the hose but not through the intake
Looks like there is some kind of door that needs to open, any ideas how I do that
thank you
    President:
  • 1,673 Answers
There is a duct(#11) that has to be inserted in place of the hose duct, in front of the tank. It won't **** from the bottom without it. If you did put it back in, then the foam filter(if yours has one) is up to high on the bottom of the tank, should be a 1/4 in. gap from the top to the top of the filter.
Posted on Mar 11, 2008
The cleaner sucks very poorly. The motor sounds fine, it blows well and there is no obstruction.
If it blows, then it should suck equally unless there is leakage on the intake (suck) side meaning something inside disconnected or cracked, letting air in from other directions. I do not know the vacuum you speak of; upright (which has a short hose often clogged by itself) or canister which might also have a leaky seal at the bag door.
Sep 26, 2015 | Vacuums
Vacuum not sucking from the brush bottom
Probably clogged at the intake. remove rug plate and check intake. Broken belt is other possibility. #5 belt. This a ver basic vacuum, so not much to go wrong.
Jan 02, 2014 | Dirt Devil M084600 Dynamite Bagless...
When the Dyson is upright and the removable parts to check for blockages are removed , sucking is strong. when the side one is reattached, the suction diverts to the outlet/slits on the bagless bin
I'm sorry to hear you're having difficulties with your DC14. From what you've described, it sounds as if the suction relief valve is activating because there may be a blockage in the cleaner head, or the internal hose.
The easiest way to check for and remove any blockages is to detach the internal hose by following the steps shown in the video below. Once you've removed any obstructions and replaced the hose, you should find this resolves the issue.
If you need any further assistance, please call us free on 0800 298 0298 (UK), or 1866MYDYSON.
Kind regards,
Jack
Dyson Online Customer Support
Nov 20, 2011 | Dyson DC14 All Floors Upright Vacuum...
Hi, my vac is not sucking well like it used to. I
If your machine has a removable hose, it may need cleaned. When the hose is removed you'll be able to look inside and see any bulky objects lodged there. Be careful removing the clog to prevent puncturing the hose.
The manufacturer's website will likely have links to service in your area.
Feb 24, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loss of suction in hose
Hi its Darran at Dyson.
It may be worth following the blockage procedure outlined in your user guide or on our website at www.dyson.com and look at our support section.
If this doesnt resolve the issue, its likely that your DC24 is still covered by the 5 year Dyson guarantee as we only started manufacturing the DC24 about 2 years ago.
If you need further help, call us on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The suction in the hose of my 2 year old Dyson Animal vacuum is compromised. I may have sucked up a small cat toy or something. Regular vac still is fine. The hose "sucks closed" after a few seconds near...
Hi there, it sounds as though the wand handle is blocked. To test this, remove the wand handle from the hose and test the suction at the top of the hose. If its strong here, then you will need to remove the blockage from the wand handle. If the suction is still poor, you will need to remove the hose by pressing in the catch on the hose cuff near the base of the machine and removing any blockages.
I hope that this information is useful to you.
Kind regards
Darran
Dec 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Not sucking up the dirty water or it's sucking up water but it's not filling the recovery tank. I've tried reattaching the lid of the recovery tank and it doesn't look like it is sitting quite right.
This is one possibility. other things to look are the screen filter on the machine. intake hose behind the motor. ensure that accessory hose cover is closed when extracting water from the floor.
Oct 06, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
The Dirt Devil 085850 doesn't pick up anything!
the intake hose is clogged thats the clear looking hose that comes up from the bottom on the back side.you will need a coat hanger wither the end bent so its rounded.on the back where you sere the clear hose it conects to a fitting that is held in by one or 2 screws take them out and work the coat hanger down through the intake hose.you should be able to push the clog out through the bottom
Dec 04, 2008 | Dirt Devil Featherlight Bagless Upright...
Suction problem
sounds like you have a leak in the suction path
look for a broken hose or seal
May 21, 2007 | Dirt Devil M086700 Vision Bagless Upright...
Suction
Opening that door and attaching the hose will let the suction go thru that hose. So if when you removed the hose, if that door isn't closed tight will cause you to have a suction problem It has to seal and have no leaks. The other thing when be a problem with the recovery tank not sealing when you put it back on. Other then that, any air leak will cause a suction problem.
Apr 19, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F5515 Hot Spot Upright Vacuum Logo
62 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
