Question about Philips 60PP9352 60" Rear Projection Television
60pp9100d/37 60" phillips
The tv was working fine,,,,then i shut it off for a moment,,then tried to turn it back on....it wont come on....it clicks,,,,then the power button just flashes...i tried unplugging,,,,that doesnt do it....please help...tv is only one year old......
  • marianthi121 Aug 10, 2008
    My husband was trying to connect a converter box on the philips projection tv. the Tv was working fine but when he tried to connect and rig 2 coaxial cables together that came in from the antenna and went to the converter box and tv the tv went off and we can not turn it back on the power light goes on but the tv does not. What could be the Problem? This is a philips 60pp950217 rear projection tv
I have a philips 60PP9100D/37. It was working just fine then I switched channels and the sound went off and the picture became fuzzy on all channels. So now there is no sound and fuzzy picture. Any ideas?
Posted on Aug 04, 2008
  • Philips Master
  • 3,459 Answers
If the power light is on but you have no video and no sound then its likely the optoic went out. You can get a repair kit at www.magnavoxhelp.com
Posted on Jul 17, 2008
  • 99 Answers
Try to check the fuse,if its broken replace with the same value.
Posted on Mar 10, 2008
Tv wont come on
Did you try unplugging the TV? Also if that does not work then call the TV provider and ask them for help.
Mar 14, 2016 | Philips TV Tuner Video Capture PCI Card -...
I have a phillips 60pp9100d that has no picture or sound. I keeps flashing I2c bus error. I have resoldered the flyback connections and anything else that looked suspect. After turning the tv back on I get...
You need to rectify the problem first then replace any part. If you have its service manual, try to daignose the reson of error and locate the problem area.
Jul 23, 2008 | Televison & Video
Phillips tv wont turn
Go to Philips web site, (enter Model number....) then download updated software & drive to update your TV software. It will fix that problem. I just did for my TV (42PF7320A/37).
Here is the link:
Download and save in USB. Stick USB on the TV' USB then updated from there.
Hope, It will work. Good look!
Nov 07, 2013 | Televison & Video
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 60pp9100d/37 - remote sensor
Yes it probley got pulled out and since
its a stragler wire ,it would be easy to miss
little trick I use is never dust or vacume
till your done , that way you can see where
somthing was or was not pluged in at that
location
darn gota take it apart again , I know the feeling.
Jun 30, 2009 | Televison & Video
Phillips Model 60PP9100D/37
Its a common problem on this model. Most likely the HVG. Goto www.TvRepairKits.com for a kit with instructions.
Apr 19, 2009 | Philips 60PP9200D Television
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers.  I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
Sep 05, 2007 | Philips 60PP9200D Television
Philips 60PP9352 60" Rear Projection Television Logo
423 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
