Back to:
Tags:
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Hot HSS25IFMMW
posted by 6kcl on Mar 10, 2008
Part of my main control board was burnt. The affected area is between J1 and the power resistor. What is causing the the circuit board to overheat and burnt? Where can I find a replacement board?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 31, 2008
Not Rated (0)
hapndnvegas
Rank:Wiz Wiz
Rating: 89%, 31 votes
replacement part here: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1194711&PPStack=1
I think GE had a run of bad boards 2001-2004 as many ppl have had problems with this board.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hot HSS25IFMMW:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezer will not defrost, tech installed round sensor that...
My freezer is working It's freezing but my refrigerator...
mntech said-to check the defrost coil aa well will that...
My evaporator fan was running sluggish then it seemed to...
I connected line to defrost on the board and the heater...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
