Question about Lexmark X4270 All-In-One InkJet Printer
Fax Back Phone Numbers
Can you give me a free fax back phone number that works all the one I find on the net don't seem to work or they are disconnected?
Thanks
GeeMan
  • Gee Man Mar 10, 2008
    Thanks anyway efax is not free this site below has quite a few but I can't get them to work.
    http://www.getty.net/texts/faxnums.txt
    I am looking for an incoming number because I am having trouble receiving.
    GeeMan
    Genius:
  • 3,587 Answers
Hmmm..you mean a free faxing number? I don't believe there are any of those..hang on..I use one for incoming, but sending them costs each time.
yeppers..efax.com
check your computers warranty here 4 FREE
Posted on Mar 10, 2008
Our HP Office Jet 4255 all in one suddenly won't receive faxes for some reason. It has been working fine up until now. We can send faxes, but for some reason the phone just keeps ringing and won't...
CHECK THE TELEPHONE NO.
Verify that you are dialing the number correctly. (i know its funny to ask)
Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
TRY DIALING FROM THE FRONT PANEL
manually dial the number from the front panel of the fax.
If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
Check the connections
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP OfficeJet 4255 All-In-One InkJet...
We have a LaserJet M1319fMFP and it appears to recieve faxes ok, but the bulk of our outgoing seems to come back much later on error reprots saying "busy," etc., but when I contact the intended recipients...
It's very likely that if you're using autodial, you've neglected to dial "1" + the phone number, or if it's part of an office that requires dialing "9" first, the speed dial or auto dial doesn't dial the "9" prior to dialing the phone number.
Jul 24, 2009 | Office Equipment & Supplies
No dial tone on my Lexmark X4270
There are two outlets in the back where you plug in your phone line. I had the same problem when I
was plugged into the far left plug (as you are facing the front of the all in one). I switched to the other
outlet and it worked fine. But still once in a while it seems to loosen up and I have to push it back in
farther. Today I got a dialtone but could not send a fax. I got a dialtone but still wouldn't send. So I
checked the outlet and sure enough, it was just loose enough to prevent the machine from registering
the fax number, but connected enough to get a dialtone.....go figure. Good luck
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Switched to shaw digital phone service from mts. my ph # and my fax # are different numbers but when phone calls come in the fax picks it up instead of the phone.how do i change this?
Call a cell phone from the fax machine to find out what the machine's number is.
Be warned, tho, fax machines will not work reliably on digital phone lines.
Feb 20, 2009 | Brother IntelliFAX 2800 Laser Fax
Cannot fax
Is thi sin an office?
Are you using a direct outside line or is it an office extension?
Your office extension may have restrictions on it and you would need to remove those.
I would confrim the numbers are fax numbers and that that line is ok by:
  • Dialing those fax numbers from a working phone line other than the fax machine
  • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
Hi, Remote Fax Error being displayed
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
DELETING PHONE NUMBERS
Hi there if you hold down one of the quick dial numbers the screen will change and ask you if you would like to change or delete. Once you have done the first one move onto the next one by just pressing the next number.
If this doesn't work then let me know and I will be able to obtain a manual from work.
Thanks J
Nov 12, 2007 | Samsung SF-560 Plain Paper Laser Fax
Lexmark X4270 All-In-One InkJet Printer Logo
342 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
