Question about Car Audio & Video
VT Commodore security coded head units
When i started my car the other day it didn't turn over the first time, when i started it the next time my radio didnt work, I tryed entering a code but i got it wrong three times, A couple days later i was able to try the codes again and i worked out that if i entered "1111" it would work for about 3 min. Is there any thing that i can do to fix the head unit. it is a second hand car so i dont have the correct code.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Call Holden with the VIN# on the car, and they will give you the correct code.
Posted on Mar 10, 2008
HOLDEN COMMODORE VT HEADLIGHT FAULT
check out a faulty headlight switch
May 01, 2017 | Holden Cars & Trucks
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
Meaning of fault codes vt commodore
no the code is not 1013
it should flash this same sequence 3 times (one flash small pause then 3 flashes large pause) and then repeat it if there is no other code. if another code is present then it will flash a different number 3 times and then start again with your original code.
DTC 13 - Right Hand (RH) Oxygen Sensor No Signal
Apr 28, 2014 | 1998 Holden VT Commodore
Car key codes by vin number
Simple. Write down the VIN # and take it to the dealer w/ proof of ownership and they will send you a new key. Most likely they'll have to program it as well for security and starting features.
Mar 22, 2014 | 1998 Holden VT Commodore
I have 98 vt ex wagon V6 manual 5speed. Went to lock with remote would not lock, so key locked next morning car would wind over fire and die. Have had mechanic out and he has confirmed my security code...
sounds like the bcm may have failed, if so new bcm and new keys and programming with tech2
thats the worst case
or
wiring issue eg ignition switch
its not reading the key due to security light still flashing
the manual over ride should have worked if it didnt then i would be checking all fuses and power inputs to the bcm from the ignition switch
Sep 16, 2013 | 1998 Holden VT Commodore
Engine stops running, temp says just above half and after a short time it starts again, VT Holden Commodore
hi pull the dip stick out have a good look at it if it looks like it as a milky coller on it mixd with the oil on it then the head has to come off and be fixd
Jan 21, 2013 | 1998 Holden VT Commodore
Eurovox stereo in Holden VT Commodore code won't work anymore
My ford dose the same thing you will need the original car booklett in it sould be a little white card which has the code on it! if you have not got the card/book go in to a holden shop or ring up Holden motors
Mar 20, 2010 | Car Audio & Video
Vt Holden Commodore stereo wiring diagram
Here are the wiring codes for the VT,
VN-VT Commodores:
Accessory (12V) Yellow
Battery (12V) Orange/White
Ground (earth) Black/White
Antenna power (12V) Yellow/Red
Front Left + Tan
Front Left - Grey
Front Right + Light Green
Front Right - Dark Green
Rear Left + Brown/Black
Rear Left - Yellow/Blue
Rear Right + Blue/Orange
Rear Right - Blue/Black
Antenna Up White (VR-VT)
Antenna Down Blue (VR-VT)
Phone Mute Yellow/Black (VT)
Dimmer In (12V) Brown/White
Dimmer Out (12V) Grey (VT)
May 18, 2008 | Car Audio & Video
Car Audio & Video Logo
809 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
