Question about Car Audio & Video
Amp there is also **where for the remote wire?onlt the 2 - and+?how do i hook it up with ** remote wire?
  • 1nomis Mar 10, 2008
    Thanks zzedly,its a pioneer gm-4200 240wx2.It also has a din plug and rcas but you can switch from one to the other but just not sure bout this as i or knowone else i know has ever seen anything like it?Cheers
  • Tygh Duval
    Tygh Duval May 11, 2010
    If you can provide the brand and model of the amp, I'll take a look.
    Sergeant:
  • 300 Answers
Unfortunately, I can't find the manual for that amp online, so I'm flying blind. If there's anything similar to "system control", that is essentially the same thing as the remote.
Another thing to try is try connecting the +12V wire to one of the "+" inputs at a time. If one of those connections is the remote, hooking +12V up to it but not the other will cause the amp to not turn on. If the amp turns on no matter what "+" input you put +12V on, then we know both "+" inputs are probably are just for +12V.
It's also possible that the DIN plug has the remote as one of the connections in it. Don't know that without the manual.
But, if the amp really, truly has no remote wire connection, you'll need to get a SPST switch or relay to turn the amp on/off. Otherwise, without a switch or remote, your amp would be on 24/7 and drain your battery in no time.
Posted on Mar 10, 2008
Runs for onlt 2 minutes
Here is the link to get the manual.
http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Feb 23, 2014 | Omega MARS-22 Remote Vehicle Starter with...
No sound out of my speakers model 5269480
on your amp under the back seat their are 2 plugs the one on the left which is the smaller of the 2 there is a Tan wire w/Orange stripe on it hook the remote wire from stereo plug which will be blue w/white stripe to that wire so it will power-up your amp...Bottom line, no amp = no sound,unless you figure what wires are the speaker wires and hook directly to your stereo plug............Its an easy fix
Oct 13, 2012 | 1994 Jeep Grand Cherokee
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
I have wired everything correctly to my phoenix gold octane 2.5:2 amp and the remote terminal is not working. i have hooked up another amp to check to see if its the remote line and any other problems but...
Perhaps the PG Octane R needs a bit more power on the remote. Check if connectors are well connected to the wire. There might be some resistant present if the connection is not 100%. (oxidation?)
Jan 26, 2011 | Phoenix Gold Octane-R 2.5:2 Car Audio...
My amp does not work
Did you check to see if its grounded well? Try grounding the amp to the battery, also check fuses. I'm not sure how you hooked it up, but I usually connect the amps directly to the battery with a heavy duty fuse. Also try the remote wire, from your cd player to the amp. Thar are usually 2 different remote wires make shure thair hooked up right, if thats all good and the amp power light isnt on then it sounds like your amp is bad.....
Dec 11, 2009 | Kenwood Car Audio & Video
Ok everything is working but the remote wire not
First make sure you have the right wire hooked up, there is a Power Antenna wire, and remote turn on wire, and both are blue, but one has a white stripe.. Just make sure the right one is hooked up.
Now if the right wire is hooked up, and still no voltage there are 2 ways to get turn on power to the amp.
Option 1.
Buy a LVT (low voltage trip), they come with instructions, and arent very hard to use. They will only turn on the amp when signal is sensed through the speaker leads.
Option 2. (I don't care for this one)
Find an accessory fuse in the fuse box (meaning only has voltage when the key is in the on position), and run a wire from there directly to the amp.
WARNING ABOUT OPTION 2. This can be noisy, and cause a whine in your speakers, this should be a last option.
Aug 08, 2009 | Panasonic CQ-C8100U CD Player
Send me info how to connect a 4-channel car amp with 2 12-inch subs rear and 2 front 2-way speakers?
plug two subs in to amp in most powerful channel then your speakers in the less powerfull take your positive from your battery and hook it to your amp your ground wire shud just touch a solid piece of metal take your remote wire and hook it to your deck all other wires shud be with your deck need n e thing else holla
Apr 19, 2009 | Car Audio & Video
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Legaxy LA2098 2400 watt 2 channel amp
Humm.. Have you check your remote wire? If you know the amp is getting power for sure, diconnect your subs from the amp leave only the + - and remote hooked up. Check again if still same thing nothing, try taking a jumper wire to the batt terminal over to the remote terminal. This should let your amp kick on, IF SO your remote wire has a short some where. IF NO i would check your ground wire again and make sure its good and along with all your fuses. IF NO still might have internal damage. BUT if it did work dont leave it hooked up like that, it WILL stay on untill u remove the jumper wire. I just use this lil trick to help save time with trouble shooting. Hope this was helpful i had the same prob with my amp remote wire was bad
Nov 17, 2006 | Legacy LA2098 Car Audio Amplifier
Car Audio & Video Logo
155 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
