Infocus projector i have an infocud ls projector also i have an laptop , im tryimng to view it says in need to adjust color , also it keeps blinlking
  • balkrishna air
    balkrishna air May 11, 2010
    Please write in details
  • 563 Answers
Hi there
Check if your Projector's resolution supports that of what you are using on your Notebook at this stage.
Example : If your Projector is XGA - your PC's resolution should be 1024 x 768
Posted on Mar 26, 2008
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    The picture suffers from colour fringing
    either the color wheel has lost a segment or the colorwheel index needs to be adjusted in the hidden menu using the color ramps test screen.
    Jul 20, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Infocus Screenplay 7210 has new bulb and I see color banding very pronounced on faces and flesh tones especially in close-ups. what to do?
    the colorwheel index needs to be adjusted, this is only available if you can get into the hidden service menu and adjusted using the color ramps test screen.
    Apr 09, 2010 | InFocus ScreenPlay 7210 Multimedia...
    Not able to adjust color and tint
    if resetting the setting to factory default doesn't work, you need to replace the colorwheel. you can get one through an infocus authorized service center, or send it to one for repair. try www.avsolutions.com. they're pretty good.
    Sep 27, 2009 | InFocus LP70+ Multimedia Projector
    DLP Infocus Problem
    first of all, the infocus lp 790 is an lcd projector, not a dlp. second, the light filter in front of one of the lcd panels is burnt, and unfortunately cannot be purchased separately.
    May 11, 2009 | ASK Proxima InFocus LP790 and Proxima...
    Colors showing red on screen
    Hi Stella,
    There is a button on the projector called "Auto Image"
    Most people don't realize it's even there.
    Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
    Note: this feature is nowhere in the menu(s)
    Good Luck!
    SagerTronics
    Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
    InFocus Proxima UltraLight LS1 LCD Projector
    There could be several reasons for this problem.
    1. New lamp needed.
    2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
    3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
    Oct 01, 2007 | InFocus X1 Multimedia Projector
    127 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
