Question about RCA 36F530T 36" TV
Tv will not come on
I have a RCA 36F530T and it will not turn on, when I plug itin the wall outlet it makes a high pitched ticking sounds that starts off slow and gets faster. Is this repairable and does anyone know what it may take to fix. I can be reached at walcorn@xanadoo.com
Wayne
    Genius:
  • 1,694 Answers
Bad flyback transformer part # 257807 possible damage to horiz out xistor # 237470...change transformer first,then xistor if you
must.....no generic....OEM quality only........T.
Posted on Mar 10, 2008
Wall plug for TV buzzes
Have the outlet checked by a qualified electrician. Sounds like either a power issue or ground. You should not get a buzz from an outlet for any reason.
If you plug something else into the outlet does it make the same noise?
If yes, something going on with the power. If not, then the TV power supply might be doing it, but the noise would be behind the TV and not the outlet.
Aug 17, 2014 | Sony Bravia 32-55 Inch...
Need schematic for harmon kardon ho-595 subwuffer
I had the same issue, definitely check your cable. if that's good try a different outlet. i had mine in the surge protector when it was making the high pitch sound. when i just went straight to the wall outlet by it self it worked great. hope this helps.
Mar 10, 2013 | Harman Kardon HK595 Computer Speakers
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
How to hookup a Sony DVD/VCR to a 36F530T
RCA 36F530T has a component video input, plus 2 rear and 1 front composite video and audio inputs
http://www.amazon.com/RCA-36F530T-36-TruFlat-TV/dp/tech-data/B0000BZHA2/ref=de_a_smtd
Jan 19, 2008 | RCA 36F530T 36" TV
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
RCA 36F530T 36" TV Logo
96 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
