Question about Linksys WRT160N Wireless Router
After setting up my router, my laptop still wouldn't pick my network up. And even when it does I cant connect. It's saying all the connectons are good so what could be the problem?
  • Linksys Master
  • 2,276 Answers
WR160N router known issues with it's FIRMWARE. wireless part of this router will not work properly if you don't upgrade the firmware. Some times it works but you will face lot of issues with this router.
Once you upgrade the firmware of the router, you will not face any problem.
Download the correct firmware of the router from www.linksys.com/download . open the set up page of the router. upgrade the firmware of the router. After upgrading the firmware, reset the router and reconfigure the router.
Click here for more information about routers
Posted on Mar 17, 2010
SOURCE:
For somw strange reason i cant pick up any internet unless i plug in the network cord into my laptop.... it used to work b4.. can someone help me?
If you connect the cord to the laptop and the router it works that means the wired connection of the router is working only the wireless connection is not working.
It might be the issue of the wireless settings of the router or the computer. You will need ot check the wireless settings of the router and the computer.
to check the wireless settings of the router , you will need to open the router set up page. Is there any computer connected to the router ?
if not then you will need to connect the computer to the router and open the router set up page.
Click Here for more information about the router and wireless networking
Jan 31, 2010 | Linksys Wireless-G WRT54G Router
Get my laptop to pick up the zoom router
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 16, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
My vista laptop wont connect through the router
you said it says connected to the network but not oline.
Check the IP address on the wireless network connection.
there might be nay static IP address on the wireless connection.
If yes then set to obtain IP automatically.
Jan 01, 2010 | Linksys Wireless-G WRT54G Router
My wireless picks up my network but wont connect. It doesnt even ask for the pass key, which it does for other neighbour networks. I have just wiped my computer.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 28, 2009 | ASUS Computers & Internet
I cant connect to the internet through my wireless
I cant connect to the internet through my wireless but it sows connecton
Aug 17, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
CAN'G CONNECT TO THE INTERNET.
How are you connecting to the router? Wireless, or wired?
If wired, is there a wired connectoid for a network card when you click on Start|Settings|Network Connections?
If wireless, is there a wireless connectoid for a wirless card when you click on Start|Settings|Network Connections?
Check out the manual here - www.westell.com/images/pdf/327w11_06_ug.pdf
Jan 20, 2009 | Westell Wirespeed VersaLink...
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can't find wireless Signal
Make sure her router is configured to broadcast the SSID as that can either be disabled or enabled. Once thats enabled and you still cant see it try and set it to different wireless channels and change the wireless network mode to 'mix"
Jan 03, 2009 | HP Pavilion dv6000z Notebook
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
Linksys WRT160N Wireless Router  Logo
254 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
