Question about Sony VAIO TX750P/B Notebook
Battery is showing as not present
My battery for a tx750p is showing as not present and is not holding a charge.
  • halrhp Dec 27, 2008
    I have tried letting charge but it simply doesn't. It's as though it isn't even there. In fact, it doesn't matter whether it is in or out, Everything is the same.
    Genius:
  • 3,587 Answers
Hmmm..not too cool..and it's seated ok? then, maybe, you might consider letting it recharge overnight(around 8 10 hours) and see if that helps a bit..deep discharge will do this
Posted on Mar 10, 2008
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
Charging led blinking
with a new one.
To test the laptop:
Dec 02, 2012 | HP Pavilion dv9000z Notebook
Power is plugged in , battery is plugged in not charging with 0% available
To test the laptop:
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
Dell Xps 15 Laptop Battery Not Charging
To test the laptop:
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
I was given a polaroid pogo as a present at Christmas but the battery will not hold it's charge I fully charge it but when I turn it on the next day the red light shows no power how do I go on about a...
try to change battery with similar one, then recharge it. usually before recharging battery level should be on low-bat condition. by doing that you can prolong the life of rechargeable battery. be sure follow manufacturer recommend type of batteries-i.e. alkali, lithium-ion
Feb 04, 2011 | Polaroid Cameras
Power and mouse probelm
there is something wrong with your battery even though the laptop shows that the battery is fully charged.
You need to get another battery for your laptop as the one you are using presently cannot hold charge, that is, the cell in the battery is weak.
Good luck.
May 01, 2010 | Dell Studio 1537 Notebook
When you turn off the computer the clock stops.
if it is the CMOS battery that is not working, then it is already for repair..
you may also call sony parts center to check if you can buy it 8004887669
Feb 01, 2010 | Sony VAIO TX750P/B Notebook
I have a sony vaio tx750p that is just completely dead, yet power is definitely going in. i want to open it up but can not find a manual to do so. also any suggestions on what the problem might be would...
Hummm.... are you SURE your supply is 100% OK? It's not enough to use a voltmeter to read the voltage... your voltage and supply need to be tested under load or with the laptop RUNNING or trying to run.
I'm curious to know if your laptop will run without the battery? Sometimes batteries get so bad the System won't start because the battery demand is so high and the supply shuts down!
So OK.... step-by-step here's a link that shows you a complete TX750P "tear-down"... I mean it's so complete the guy has the mother board in his hands... NOT for the weak of heart!
HUGE WARNING! Laptop s---ws are not always the same length! If you replace a short s---w with a longer s---w you MAY damage components below or some parts may not mount securely! They are the LENGTH they need to be... so use some method to keep track of where each came from.
I use just the bottom half of a egg carton (top cut off) and different colored felt pens to mark a few egg cups. A color dot on the metal chassis to match does the trick. A red black and blue marker should be enough...
Also the guy is shown using a slick tabletop ~ I do NOT recommend that... Work and disassemble on a soft towel so a dropped screw won't get lost in space! The towel does not need to be too thick ~ just enough to provide a soft working base and so you won't scratch your laptop covers!
Anthony
SONY VGN TX TX750 take apart video disassemble how to open disassembly
Nov 17, 2017 | Sony VAIO TX750P/B Notebook
Re:battery
Great, you now know the system uses the battery, when you unplug the AC adapter and if it turns off the battery is not holding a charge and will need a new battery.
Here is a link for a new battery :
http://cgi.ebay.com/PANASONIC-TOUGHBOOK-TESTED-GOOD-CF-73-BATTERY_W0QQitemZ230277844568QQihZ013QQcategoryZ101256QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
rate please, was a pleasure helping
Sep 16, 2008 | Computers & Internet
Sony VAIO TX750P/B Notebook Logo
163 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
