Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Heating element in GE Range Oven
Hi, I have a GE Range oven it is at least 10-15 years old. I think it is a cheaper model with the electric top. Today I was baking and the oven started humming really loud like a buzzing sound. I went to check the oven and the heating element was on fire. The heating element is now cracked. Also, the top of the stove where the burners are were really hot as well. Am I better off just replacing the heating element or is this a deeper problem. I am afraid that maybe the problem is more than the heating element.
thanks
  • 1 more comment
  • robertj1 Dec 01, 2008
    I notice after baking some biscuits, that the bottom of the biscuits were not being cooked/browned properly. When the oven cooled off I notice the bottom baking element had cracks in it, plus not supplying any heat.
    I bought this GE range new 12 years ago.
  • Anonymous Mar 22, 2014
    The oven makes a loud buzz/hum when plugged in , but not in use. It appears to come from the display panel.
  • Anonymous Mar 23, 2014
    Electric stove top: when power is going to the element, it makes a kind of groaning sound. As the power cycles on and off, it makes a repetitive sound that is quite irritating.
    President:
  • Kenmore Master
  • 2,651 Answers
Get the model number and order the exact repacement bake element
Posted on Mar 10, 2008
My GE Profile is about 10 years old. Everything
cheapest attempt would be replacing temp. sensor....other component if still not functioning,would be the main computer board,which can be very pricey
Nov 27, 2009 | GE Ovens
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Oven won't work
It sounds like your heat ignitor went out. To find out open the door and look for a 1/4" rod that starts in back and wraps to front then to back again that is it. shout door turn on oven to se if that get bright red I would start at 475 degrees. If it does not get bright red it went out and needs to be replaced. If I get model # I can get part # and manual to show you how to replace it. Or you can cal out an appliance repair man.
Good luck.
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
503 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
