Back to:
Tags:
Acer
Acer Motherboard MS6772
posted by downandout2 on Mar 10, 2008
Acer motherboard MS6772 ver 1
Can you help me with the pin out for connector FP1 please
This is the connector with reset and power switch drive led etc
Comment by downandout2, posted on Mar 10, 2008
thanks Terry ,
What I'm after is hardware information ie connector pinout
Regards
Alan
ah...micro star , thanks ...thats a big help
regards
Alan
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
tkw2201
Rank:Wiz Wiz
Rating: 82%, 172 votes
go to www.driverguide.com
you need to register it is free .
then search for the drivers you need
good luck
Terry
Comment by tkw2201, posted on Mar 10, 2008
sorry i should have said look for the manual for your mobo on the net it is a ....micro star mobo
good luck
Terry
Rating Locked! (?) downandout2 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Acer Motherboard MS6772:
I don't want to Accept this solution
Solution #2
posted on Sep 13, 2008
Not Rated (0)
Wayne at ROC
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This board uses typical INTEL styled pin header for front panel connections and is used on many major OEM boards. Here is the pin assignment:
Pin 1-3 HD LED (Red color in this particular board)
Pin 2-4 Power LED (Green)
Pin 5-7 RESET
Pin 6-8 Power ON/OFF
Note: Pin 10 is empty
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on May 21, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
sorry Guest , can you repeat please
I only speak english
Alan
Thank You!
Solution #4
Not Rated (0)
Guest
Rating: 0%, 0 votes
mira yo tambien ando buscando el manual de la tarjeta madre que viene en una pc de marca ACER , yo tengo uno si te sirve escribeme a mi mail y te lo paso quetzal6@hotmail.com
Thank You!
Can you Help with these Motherboards problems?
Motherboards
pcchips m810 rev 7.1a ¨q8-overheats then gets...
Motherboards
i have msi p45 platinum MB,two graphics cards xfx 9600GT...
Motherboards
I took apart my sister's computer an XP and I'm having a...
Motherboards
hey i need help with my problem that im haveing with my...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
