Hi, it sounds like a blocked vent. Outside, where the warm moist air exits the building, verify you have good air flow. If not, pull out the dryer and make sure there is no restriction, kinks in the vent hose, lint build-up, etc. If you have a vent restriction, it causes the heating element or burner to over heat and shut down prematurely which extends the dry time considerably.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
