Question about IBM Wheelwriter 30 Typewriter
Margin Problems I have an IBM Wheelwriter 30 Typewriter Series II, and I can set the left and right margins fine, but when I get close to the right margin, the typewriter beeps and as I keep on typing, the carriage moves past the right margin and ***** skips down to the next line. I checked the formatting and the typewriter knows that it is past the right margin, but it doesn't do anything about it. Thanks
  • 478 Answers
It sounds like you have auto return turned on
Posted on Mar 10, 2008
  • IBM Master
  • 3,594 Answers
You are in auto return. Press code and R
This should doit
DickyO
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
Right margin
Hi:
On all IBM Wheelwriters the right margin can always be typed through. The only indication you will get when you reach the right margin is a beep tone. To set the right margin, space to the desired point and depress the right margin key once.
Andrew
Jul 16, 2009 | IBM Wheelwriter 30 Typewriter
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
DicktO
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 won't let us clear the left margin
If the carrier (print head) goes to the left when you turn the T/W on then try this.
Return to the L. margin, press mar rel key, backspace to the location that you want the margin, press L. mar key the wheel should spin and reset the margin.
DickyO
Oct 16, 2008 | IBM Wheelwriter 30 Typewriter
Right Margin
First with the T/W off move carrier back and forth checking for binds or anything binding the carrier if there are no forgien objects try a little WD40 on the shaft that the carrier slides on. DickyO
Oct 14, 2008 | IBM Wheelwriter 30 Typewriter
Margins
L. margin - return to current mar. press mar. rel. key, backspace to the wanted location press L. margin key.
R. margin - space or backspace to desired location press R. mar key.
The margin keys are on the left side of the keyboard.
DickyO
Jul 10, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 (Setting the Margin back to 5"
Sounds like you don't know how to set l. margin or you have some debris in the typewriter. Turn it off and see if the carrier will move back and forth by hand, if so turn it on 7 return to l. margin press mar rel key, backspace to where you want the margin and press l. margin key.
hope this helps
DickyO
Jan 15, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
MARGINS
Move carrier to left margin press margin release, top left hand side of keyboard, back space to desired position and press L Margin key.  Margins will reset to default if batteries are dead.   Right margin simply space to whever you want the margin and press R Margin.
Oct 24, 2007 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
213 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
