Question about LG WM2688H Front Load Washer
Parts manual how can i get a parts manual for the wm2688h washer front load, i need the pump motor for this machine, any help, i've checked the pump filter and evrything is fine it's the pump motor thats blown out. thank you
  • johnlongz28 Dec 04, 2008
    I have a Samsung WF337 fills with water to wash, drains, then when it's time to refill I get an error code nf. NF meaning didn't fill (I can see). But when I run it on rinse cycle it fills and rinses and drains and works properly. I get the nf code on all cycles except on rinse cycle. Keep in mind that it will fill and drain on all other cycles. Just when it time to fill again it codes. Any help will be useful. My parts and labor is 12 months and I've past that. The control board is 24 months and I'm still in range for that. THX
    President:
  • LG Master
  • 2,651 Answers
Ahhhhhhh i hate lookin up these lgs. imgonna give you 3 numbers. 4681EA2002D this is the rt side motor. 4681EA2001D heres the left side motor. and finally is the pump housing itself 3108ER1001A. the drain motor cant be ordered as 1 piece. that would be to easy. but that will cover the 3 parts of your drain pump assy
Posted on Mar 10, 2008
    Genius:
  • 3,587 Answers
Well..the parts manuals are hard to find from LG, since they are an Asian company. however, if you get the part number from the pump, you can enter that in Google, and you'll be amazed at how many options there are for this.
Why is my LG front loader leaking from bottom front of washer?
When cleaning the filter you may have dislodged the o-ring seal on the filter unit. Check the condition of the seal or if missing replace it with a new one.
Sep 13, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I keep getting a oe code and it wont drain
That is actualy a DE (drain error) code. Open the access door at the lower left on front of the washer. Use the little hose to drain the remaining water out of the machine. Now, unscrew the big knob next to it and remove the attached filter. Clean out the filter and re-install. If the filter was clear, you will need a new pump motor.
Jan 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm LG Washer
Santa says that "OF" code is really a "DF" (drain fault) which means check the filter (behind the access door at the lower left on front of the machine). There is a small drain hose next to it which should allow you to drain out the remaining water in the machine before you remove the filter. If the filter is clear, it is possible that the impeller on the pump motor is off, which requires a new pump motor. (if you push the impeller back on, it will only come off again) Santa would like a "fix ya" rating this year. thanks.
Sep 18, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Part number
nope..same issues from my end. LG is really tight with their information, which is funny, considering how thin their service coverage is in US..
Mar 10, 2008 | LG WM2688H Front Load Washer
LG WM2688H Front Load Washer has no power
You may have a failed control board and it will need to be replaced.
Oct 17, 2007 | LG WM2688H Front Load Washer
LG WM2688H Front Load Washer Logo
221 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
