Question about Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo code i get an dl f code and my machine won't start
  • ttb51 May 26, 2008
    I get an F20 code and the washer stops. It will not let me reboot it or move to another type of setting... very frustrating and the wash is piling up.
    Tawanda Turner Brown
  • stock03 May 26, 2008
    "F02" is the code I'm getting.
    The machine starts, but only for a few seconds. Then it stops, and the timer continues to count down. after several minutes, it will beep and then flash the "F02" code. I can't reset it either. Also, it now smells like burning electronics.
Where does dl located
Posted on Mar 11, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
You got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Posted on Mar 10, 2008
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore smartwash error code dl and f? Won't start.
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the problem is solved. Please get back to me if you have any other questions.
Kevin
May 26, 2011 | Washing Machines
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor
Control Unit (MCU) cannot be sent correctly.
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9150PWO Whirlpool duet
take bottom panel under door off there 3 screws you 'll need a star tool reach on the right hand side there is a yellowgreen strap pull it and door will come open
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
no this model isnt a big problem but they do have some issues but they all do i work on all name brands and the whirpool is the one i like the most
Dec 08, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
380 people viewed this question
Dan Webster
Dan Webster
Sal De
