Question about Krups Bravo Plus 872 Espresso Machine
2 problems: not enough hot water, and where the rubberized tube goes
Hello experts,
I took apart my Krups espresso machine, cleaned out the gunk in the boiler, and put everything back together except for the 4 inch rubberized tube (which I can't remember where it goes). The milk frother works great. But when I try to make espresso it's really steamy, and not a lot of water coming through -- so not much espresso is made. I thought it might be a gasket problem, so I put a new one in the part where the hot water comes out to drop into the espresso basket -- but the machine still isn't producing enough water to drip on to the espresso.
1. where does the 4" rubberized tube go?
2. why isn't enough water coming through? (all the screws are down pretty tight).
Thanks,
Joan
thanks,
Joan
  • joanmo Apr 08, 2008
    Thanks for the quick response. Hurt my wrists while cranking screws down on the machine. So now I'm back at trying to fix the thing.
    Ok. Still not sure where the tube goes. Here's a photo of my machine, plus a line drawing of the parts which doesn't include the tube for some reason.
    Thanks,
    Joan
  • billcox Jun 02, 2008
    I cant get any water to come down into the brewing basket. I have taken the filter etc. out and run lime away thru the system several times. I got the steam to come out the steam pipe on the side but just a little steam out of the hole where the water comes into the brewing basket. thanks
  • 25 Answers
It's my opinion that the tube goes in the boiler so that when the water boils, the steam will push the water up the tube and to the brew head. Without the tube, you will just get steam through the grounds.
Posted on Mar 10, 2008
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
Not dispensing water
I have the same problem, took it apart and looks like the water connector after the water heater has a relief valve that is shooting water out of the relief part. Took it apart and the plastic part inside has crumbled apart from the heat. The part has three hoses that connect to it with a black relief valve on the top. I don't have a part number for it yet, but Krups should be able to tell you if you describe it. If you still have the machine, here is a guide to taking it apart:
http://urbanoia.net/?p=714&cpage=1#comment-392
Good luck.
Apr 19, 2012 | Krups Super Automatic XP 9000 Espresso...
When I want to make coffee the water doesn't go to the revolver but down to the water reservoir. It just started few days ago before that the machine was doing great. How to fix it?
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
May 19, 2010 | Krups XP 4050 Espresso Machine
No espresso coming out.
Apr 20, 2010 | Krups XP 4050 Espresso Machine
When doing espresso all water comes in the waste basket. Nothing in the cup. Steam function and hot water funcrion is working.
Apr 10, 2010 | Krups XP 4050 Espresso Machine
My xp7240 has also started leaking water from beneath the machine
the distribuitor as down!
its dificult to substitute. maybe find an expert its a good option for this case.
Jul 02, 2009 | Krups Small Appliances Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
No froth
Make sure the small metal tube is clean as well as the holes in mounts into. The tube can be removed easily from the rubber ends and cleaned. I've had my unit for a year now and we use it ever day without this issue ever happening. I did have the constant beeping water leaking from the seat/valve problem which I fixed by opening up the unit and tightening the screws.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
May 24, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups Bravo Plus 872 Espresso Machine Logo
829 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
