Question about Whirlpool Duet GHW9150P Front Load Washer
Shipping/transport bolts can anyone tell me where i can find instructions on how to put the bolts back in?
  • 1 more comment
  • mariais Mar 12, 2008
    yes, i kept the bolts, thank goodness, thanks for all the suggestions. still no luck finding instructions. but i'll try wiggling the bolts back in, maybe with the top of the washer off.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    hmmm? that's usually part of the packing materials. do you still have those around?
  • Gloria Hanna
    Gloria Hanna Jan 18, 2013
    i cannot remove one of bolts
    President:
  • Whirlpool Master
  • 2,651 Answers
You can probly down load acopy of the installation guide from the manufatures web page. but all you'll need to do is re-install the 4 bolts back into machine from rear panel thers only 4 oval shaped holes on the rear of unit, that would accept them
Posted on Mar 10, 2008
Install shipping bolts
This will not be necessary if the machine is transported on its back lay it down carefully on its back should not be a problem
Nov 06, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Just put in and washes fine but when on spin it jumps everywhere we have followed all instructions are we doing something wrong
sounds like either its not level or you left in the shipping bolts that keep the tub mounted for shipping bolts are removed from back of washer.....
Jan 31, 2011 | Bosch Washing Machines
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot (http://www.homedepot.com/Appliances-Laundry-Clothing-Care-Washers-Front-Load-Washers/h_d1/N-5yc1vZ1xr5Zbv6h/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053&omni=c_Front%20Load%20Washers). The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
Dec 12, 2010 | Washing Machines
Need transport bolts for my Whirlpool Duet front load washer, model # WFW8400T,
The transport/shipping bolt for your washing machine is part number 8540199. It is sold as set of four here.
Aug 21, 2010 | Whirlpool Washing Machines
Transport Screw
The "transport or shipping" bolts are located at the rear panel of the washer. There are four of these bolts used to support the suspension system during the transport to prevent damage to the washer. These bolts are removed prior to the first use of the washer and caps are usually placed in the holes left by the bolts. When removing the bolts, remove the lower ones first then the upper ones. Keep the bolts and spanner, if there's any, for future use.
Mar 22, 2010 | GE Energy Star WCVH6260F Front Load Washer
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Jumping
On all front loader machines there are some transport bolts that fix the drum. Normally on the back of the machine, sometimes under the lid. Remove these bolts and the plastic "tubes" that they pass through and it will release the drum. To test if they are in still, open the door and put your hand in, then try to bounce the drum, if you can't then the bolts are still in. There are between 3 and 5 bolts and usually a cover with the instructions to tell you how many.
Apr 29, 2009 | Frigidaire Affinity ATF6000F Front Load...
URGENT~no clue how to reinstall transport bolts for moving washer
The long one go on the bottom and the short one go on top the hole for the shipping bolts are on the back might have a clear plastic cover over the holes on the back panel there is only one way to put them in start by hand tighten the bolts with nothing in the drum the holes should line up one you fill the catch and get hard to turn start using a wrench when it is done try shaking the inner tub it should not move all the shipping bolts do is keep the tub from slapping around inside the cabinet and breaking things Good luck
Apr 03, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
433 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
