Question about Fujitsu 18C1 Air Conditioner
Fujitsu ASU9RLQ I have a new mini split heat pump/air conditoiner installed. The electronic air cleaner does not operate correctly. After 4-5 minutes of operation, the Operation (red) light on the front of the wall unit flashes 4 times and the Timer (grn) light flashes 7 times indicating an air cleaner monitor trial protection error. The filter is clean (new) and the front panel is closed. I'd appreciate advice re how to resolve the error.
  • 3 more comments
  • Anonymous Mar 12, 2014
    the air conditiong works 5 minutes then condenser stops
  • Anonymous Mar 14, 2014
    lg mini split error codes cooling light flashes 7 heat light 6
  • Anonymous Mar 16, 2014
    power triped, now unit display this error code via flashing LED
  • Anonymous Mar 20, 2014
    Tried to reset, but no error code
  • Anonymous Mar 30, 2014
    flashes 4 times than pauses and starts all over again
  • 86 Answers
Check indoor unit sirkit board
Posted on Mar 15, 2008
My fujitsu mini split is tripping the circuit breaker on heat mode after a few minutes of operation. the a/c works fine. It makes a lot of noise just before tripping
If I had to guess you have a bad reversing valve. valve sticking, compressor not being able to pump refrigerant, then drawing high amps, overheating and tripping the breaker. If you have tools and experience, try tapping on the valve gently to free it up while switching.
Dec 24, 2017 | Fujitsu Heating & Cooling
I have a fujitsu aou24rml that i am installing in my house and the tag on the unit says 230/208 volts but the terminal block only has L and N witch i think is for 110 volt
Based on the specs that I could find, that unit requires 208/230 volts. Are you sure you are looking at the correct terminal block. It should be more like L1/L2. Do you have the install manual and does it tell where to hook up the supply voltage?
Oct 11, 2014 | Fujitsu ASU24RLF HFI Wall Mounted Mini...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
AC unit
You should post this question in the air conditioner section so the proper experts will see it.
Sep 05, 2012 | Fujitsu Halcyon ASU9RMLQ Mini Split Wall...
I bought and installed an ASU9RLQ that had been
Install new batteries, aim it at the unit and press the power button. You should hear a beep or see a green signal. If not, try to command the fan to come on.
Jul 09, 2010 | Fujitsu 18C1 Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
1,221 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
