Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi model # vs-5055 will power off after a minute or so
Mitsubishi will not stay on after a minute or soHave a VS-5055 and can,t see anything on the screen
Can,t eve see the menu sound is there help
  • 2,923 Answers
Is there a green or red light blinking? If not:
The reason there is no picture is (95%, certainty) the loss of the high voltage. The high voltage is what produces the energy for the raster lines upon which the video is modulated.
Therefore, the video and deflection circuits may be working just fine but you cannot see because there is no high voltage to the picture tube.
Now, it is possible, also that power to the picture tube filaments has been lost, or that the power supply to the biasing voltages is defective or that the picture tube sockets are corroded, but the overwhelming cause among TV sets is loss of high voltage.
Refurbishing the high voltage will probably cost $250 or from anywhere you go. Even if you do it yourself and buy the parts wholesale you will not save a tremendous amount. So, unless you are very handy and know how to troubleshoot, solder, repair and test, I think you are better off finding a good shop for the repair.
The tech needs to check or replace the high voltage circuit or the power supply board.
Posted on Mar 16, 2010
I have a Mitsubishi TV model VS 5055 1994. The
you need to replace convergence IC chips to resolve this issue .
Nov 28, 2010 | Mitsubishi Televison & Video
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
VS 5055 has distoration, discoloration, screen not complete.
Do self diagnosis test by pressing input and menu on set at the same time for 5 sec. It should blink a 2 digit code. Remember code and let me know.
Nov 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Most older TV's require hand-soldering at least once in their lives,esp. regulator pins in power supply circuits.That work
requires the chassis to be pulled = major labor.......T.
Nov 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS 4543, Picture go out after a few minutes
I usually find that symptom you describe is caused by cracked solder joints on the power regulators or vertical output IC. I have also seen that symptom caused by loose solder joints on the vertical windings up inside one of the yokes. If you have experience in repairing TV's then you can disassemble the set and pull the main chassis, flip it over and resolder all of the parts mounted on heat sinks. If you do not have experience in repairing projection TV's then allow a qualified tech to handle it for you.
Aug 05, 2007 | Mitsubishi VS-60607 TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
