Question about Vizio L32 32 in. LCD HDTV
Tv wont change inputs vol. wont work - Vizio L32 32 in. LCD HDTV
  • usman13 Mar 29, 2008
    i have a vizio 32 hdtv none of the inputs in the front work. If you hit power, volume..etc tv turns off and turns back on in 30 sec. The tv is stuck on channel 3. I have unplugged it and back in no change..
  • 31 Answers
To get any more detailed I need Brand and model number. But first thing you always want to try is to unhook it from power outlet for 10=15 minutes, not just power off actually unplug from power, next if that fails try manually pushing all the buttons on front panel several times each in case one of these has data locked up. next on newer units they have to see signal on each input to change to that input so make sure you power on each source and then turn on tv. also while each item is on go to menu and go to auto program)i had one like this Friday) then auto program unit again with all sources attached. good luck if this no help get back wiyth brand and model and we can continue
Posted on Mar 10, 2008
I can't enter service menu on Sharp TV 60LE751
Give this a try...
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu
Mar 22, 2014 | Televison & Video
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Dec 29, 2010 | RCA 32V524T TV
We have no picture or sound on our Philips TV. We can pull up menu and our DVD player works using the TV. Model # 55PP9910-17; SN YA1A0443050810 Can you offer some assistance???
TRY 1. have you tuned tv in ( need ariel in first ) or
2. put tv in the corect input mode ( dtv or tv mode ) or
3.this will reset tv unplug tv and hold VOL UP and VOL DOWN together on the tv keep hold of them and plug in tv and press standby on remote then let go of vol up and down tv will come on answer on screen questions (e.g language )
Dec 04, 2009 | Philips Televison & Video
Tv video input wont work on remote that came with dish but vol goes up and down i have insignia tv
The tv video but will have to be accessed by pressing the clear tv button then pressing tv/ video, however some functions are not guaranteed to work on some model tv's.
Oct 27, 2009 | DISH Network IR Remote Control
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Connecting DVD
External inputs are accessed in the game mode
set must be in game mode to see video
Press the MENU button so that the menu display appears on the TV screen.
Press the VOL(ume) ▲ button so that "PICTURE" is selected.
Select the feature you wish to adjust with the CH(annel) ▲ or ▼ button and adjust it with the
VOL(ume) ▲ or ▼ button.
GAME MODE
Set to the most suitable position for TV
GAME.
[+] : ON
[-] : OFF
When you press the GAME button if the TV is
off, the TV turns on and will be in the Game
mode and external input mode automatically..
Nov 23, 2007 | Symphonic ST419E TV
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
