Question about Canon PIXMA MP510 All-In-One InkJet Printer
Printer not feeding paper correctly PIXMA MP510 multifunction Printer
I can't figure out what's wrong with it but my printer won't feed the paper correctly through the printer. It starts out by pulling more on the right rather than evenly. I think there might have been something dropped in there a while ago but I've turned it upside down, looked at it, shook it, shook it again, yelled at it, cleaned the roller, tried it again, have a ton of botched papers on the floor and don't know what to do anymore. There's not thing helpful on the Canon tech support website and nothing has been helpful via searches.
Please, I like my printer but need it back to functioning status ASAP.
Thanks,
Liz
  • 9 more comments
  • WeeElly Aug 12, 2008
    I am having the same trouble with my printer. It started only pulling on the right side, but now it won't pull on either side.
  • Anonymous Aug 13, 2008
    I have identical problem-help
  • epjulie Aug 20, 2008
    yes i have exactly the same problem it starts to take paper then stops
    even the bottm feeder fouls aswell.
  • Anonymous Sep 01, 2008
    SAME!
  • handis Sep 08, 2008
    Same bloody thing here. Cleaned the rollers, tried to check for pins etc. inside... HALP!
  • elithpro Sep 13, 2008
    same here, sigh. my printer wont print/feed evenly. Any solution?
  • kelknott Sep 22, 2008
    I have the same problem. Am about to buy a new printer. Its like one of the rollers inside doesnt work. Typically its just out of warranty too.
  • Anonymous Sep 25, 2008
    Same problem. Mine starts to feed the paper, then stops halfway through and a message comes up that says its out of paper! How frustrating. I have opened the back and looked to see if there is anything in there, turned it upside down...nothing. Please help!!
  • MousieT Nov 02, 2008
    I have the same issue and tried all printer maintenance for my printer from the manual. Any solution would be helpful. Thanks.
  • Anonymous Apr 14, 2009
    argh, tis a pain. any help anyone?
  • Anonymous May 03, 2009
    same exact problem. =|
Not sure if it will do it for you guys but after poking around, shaking, etc etc, i hadn't found a solution to the paper jam, I ended up trying to scan and print something, and, the paper aligned better at first and then i tried again after some error messages popped up, turned off the printer, rescanned and it didn't sound good at all, but dislodged a nail, that had fallen into the back cavity! now its working fine, so give it a shot, could just be that something has fallen in and is lodged. hope this helps.
Posted on Apr 14, 2009
I had the same thing happen to me.  It starts out by pulling the paper crooked and then gets stuck before it ever makes it to the next set of rollers.  I even tried feeding from the top feed but had the same problem.  Another bad thing is that the printer sprays the whole inside with ink since it thinks there is a piece of paper there.  So I have been forced to clean my printer after every failed attempt.  I highly doubt that we dropped something in it if we are having the exact same problem.  I wish that someone could find a solution to this problem or else I am going to end up trashing this one and getting a whole new printer.
Posted on Jun 28, 2008
Canon PIXMA MP510 problem with j feed
Is mechanical problems,gears blocated,you must be remove the covers and look attent the transport drive mechanism components.
Feb 16, 2013 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP510 Printer says "no paper" please help!
It is best that you take your printer to a certified service center for Canon, its possible that it just need cleaning and that something is tripping the sensor and sending the wrong signal. Gheck if the paper feeding sensor is ok, usually the trigger could be broken, compare it with the same printer and look for differences.
On the otherhand, if you are sure and you are a technical person with repair experience, please check with the Canon main distributor or sales office near you. They have parts specific to your needs, if not they can point you to the right place.
Another alternative is to go a Canon repair shop and ask if they have a scrap printer with the same model as yours.
Jul 29, 2010 | Canon PIXMA MP510 All-In-One InkJet...
More than one piece of paper feeds at a time
try fanning your paper before putting it into the printer, in moist climates the paper can absorb humidity and make it stick together.
Mar 29, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Paper goes in but does not come out
I would suggest opening the printer up and taking a good look inside to see if there is any kind of obstruction. Jus a tiny piece of torn paper is enough to cause the whole feed system to jam up. Another thing to look for it that if the paper it getting pulled in straight. If it goes crooked on its way in, your paper feed itself might be the root cause.
May 06, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon Pixma MX850 says it's out of paper when there is paper
The feed switch changes the paper feed from rear feed to tray feed (paper tray is under the output bin). If you have paper in the rear feed, the green light should be on top of the printer icon left of the feed switch. If you have paper in the tray, the light should be on the bottom of the printer icon.
Apr 14, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon MP510 prints uneven lines.
I assume that you've cleaned the nozzles and alignment utility.  Try wiping the carriage bar with a lint free cloth dampened with rubbing alcohol. Also, the paper feed rollers may have collected some "goo" and should be cleaned with the rubbing alcohol. This should clear the problem.
Mar 15, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Mp510 rear feed
built up dust can smooth the rollers, try cleaning with a cloth.
Dec 11, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
286 people viewed this question
old marine
old marine
