Question about Altec Lansing ATP 3W Computer Speakers
Atp3 wont power up why?
My speker doesnt have a power when i turn the ****? what might causing this problem? ive checked the connection and everything, it works just great last week and **w ** power i,ve even change the outlet where it is plugged. pls help me thx
  • 3 Answers
There is an internal fuse in the Altec Lansing Speakers ..BUT BE CERTAIN TO DISCONNECT THE POWER LEAD BEFORE MAKING THE FOLLOWING REPAIR.AS IT CAN BE DEADLY!!!
If you remove the larger screws from the back of the unit then remove the top section with the circuit board attached. Next remove the screws attached to the bass speaker as you will need to remove the speaker to replace the fuse.
Once the speaker screws are removed there is a little recessed slot in the timber for you to put two fingers in to lift the speaker out. It may offer a little resistence as there is a dab of glue holding the cables into the cabinet next to the speaker.
Once you have the speaker removed double check that you have disconnected the correct power lead to your ATP3.. The fuse is easily visible so pull it out and check with meters to see that it has not blown.
Alternatively take a 9 volt battery ( the type with both terminals at the top of the battery). Place your tongue over both terminals to verify it has a charge (you will feel a slight tingle on your . tongue).
Next place one end of the removed fuse on one of the terminals.. now short curcuit the other end with your tongue touching both the unconnected end of the fuse to the other unconnected terminal ... this should complete a circuit and give you a slight tingle.. ( it wont hurt you!) If there is no tingle the battery is either flat or you have a blown fuse.
If the fuse is OK, then chances are you have a faulty pin connector - your "right out" connector. Sometimes these get bumbed with the feet if you have it on the floor and they can lose the contact needed to switch your unit on.
You then need to either re-solder the pin out socket on the circuit board or repair the cable that plugs into it.
If someone has worked out how to solder a jumper lead on the board at the pinouts you may be able to have the power on permanently and then use the wall switch to turn it off and on.
Posted on Apr 13, 2008
  • 34 Answers
You could have blown an internal fuse depending on the power options and how long and high you had them. The definate way to know is to try them on another computer. To they turn on at all or is there just no sound. If they turn on, jus without sound then you may have blown a speaker but if the don;t even turn on then maybe you blew a fuse. Either way the damage is not really fixable. Also, did you check your device? The power (volume) may not be high enough on the device. If using a computer then goto volume control and check each setting on the pannel for mute, balance options and most importantly, volume. One seemingly unimportant seeting could be the difference between hearing and not hearing your valuable system beeps and music.
Posted on Mar 10, 2008
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
My iphone 3gs isnt turning on and my computer wont recognise it. ive tried to hold the home and power button but this doesnt do anything. the "connect to itunes" doesnt come up when i plug it...
Try to hold your home and power buttons again until you see the Apple logo. I'm assuming you don't have any issues with your home button being unresponsive. If you have that issue/problem before with your home button, try to push it harder for it to work.
Also, try to connect it to your computer and see if your iTunes will detect it too.
Mar 07, 2011 | Apple iPhone 3G Black Smartphone
IPhone charging problem
If you are using a genuine apple usb lead, replace the charge port in the phone.
Sep 26, 2017 | Apple iPhone (16 GB) Smartphone
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Car wont start
Check all wires from battery to starter are connected and clean and tight.If they are then your solinoid is your problem.
Jul 09, 2009 | 2003 Kia Spectra
ATP3 intermittency problem
I've had intermittent speaker problems with these models and it was caused by slight abuse, ( stress on the speaker jacks at the main board located in the main subwoofer cabinet). The problem can lead you to believe its the speakers or the wires but in my case it was a loose solder joint on the main board in the subwoofer. I had to take the subwoofer apart and carefully re-solder the connections of the speaker jacks. I've had no problems since. I've also been a little more careful not to push the jack side of the connection against the wall, kicking with my feet etc..
Aug 03, 2008 | Altec Lansing ATP 3W Computer Speakers
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
No power to my legacy 600 watt car amp
Hmm...ive had this problem before and its always been either the remote wire, the rca cables or the ground. i would try hooking up the remote wire strait to the battery, if that doesnt work try to find a better place for the ground. maybe where your trunk latches. if that still doesnt work then i would try new rca cables.
Feb 13, 2008 | Car Audio & Video
Altec Lansing ATP 3W Computer Speakers Logo
349 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
