Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung HCN4226W Green Tint Around Corners
Hi, I own a Samsung rear projection tv, model number hcn4226w. About 2 years ago, I had the convergence modules replaced. I stored the tv at a friends house for awhile, and when I got it back, it was in black and white in coaxial, and in A/V hookups. It still has color in Component and DVI, although there is a green tint where whites should be, especially around corners. It's a great picture and the colors are lined up great, so I don't think it's a convergence problem. But if I knew what was wrong, I wouldn't be asking here. Any advice would be great.
  • 3 more comments
  • torupp1 Mar 10, 2008
    It's not like a speaker tint, it's all the white anywhere but right in the middle of the screen. The tv seems to have very earthy tones even when I put it on cool color tone. The light on the power button blinks red before it turns on, not green like it used to, but the tv still powers up fine.
  • torupp1 Mar 11, 2008
    I'm pretty tech savvy, so the convergence is old news for me. I have to readjust it every time i turn on the set. I know its more technical, I just don't want to waste money on the wrong part or something
  • torupp1 Mar 13, 2008
    Nope, that just gets the red and blue in line. It doesn't seem like it's the convergence. It almost seems like the green tube is overpowering the red and blue to give a green hue where white should be.
    I will definately try that. It's something I haven't thought of. I will let you know the results.
  • torupp1 Mar 14, 2008
    Ok, so there doesn't seem to be any adjustments that look like those. There are adjustments right on the bottom of the lenses with wing nuts that I can loosen and then focus the light, but that seems to do nothing for my problem.
I think the problem is the Blue Bulb Going out causing the red and green to over power. I have this same model tv with the same problem. I was thinking that or the High Voltage board. When the Tv is on a black comercial it has red small flashes going, covering the screen.
Posted on Dec 08, 2008
Well the first thing i would do is bring up a cross hair pattern and check that the convergence is agained if it is then you have something else going on...
Posted on Mar 10, 2008
    President:
  • 4,402 Answers
Sounds like the alignment of the convergence in that area needs to be preformed or you have a speaker or something in that corner
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
Yellow Tint over picture...
well..it's simple really...yellow is from a degrading video unit and system board..so, you'll find that it's high time for a major service situation.
May 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Tv fails to power on red light glows around power button on tv
there is somthing like puse in the back in side it cost u near about 200 $ put that it gone work 101percent
Dec 12, 2008 | Samsung HCN4226W 42" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226w green color problem
The green that you see is the DMD board (digital mirror display) going bad. Very common for this model.
Mar 24, 2008 | Televison & Video
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
My blue color is off...HCN4226W.
If the blue is shifted away from the rest of the picture and maybe bowed then try the manual convergence adjustment. My guess is the red will move but the blue won't. If I'm correct call a tech unless you are a skilled solderer, then replace the large STK amps in the Convergence circuit and check all of the resistors in the circuit. Good Luck.
Dec 28, 2007 | Samsung HCN4226W 42" Rear Projection...
RED Ghost Image on Samsung 42" Rear projection HDTV (Model - HCN4226W)
I WOULD RATHER THINK IT IS ONE OF THE CINVERGENCE AMPLIFIER & DRIVER IC,S A REAR PROJECTION TV NORMALY HAS 2 OF THEM AND THEY ARE THE SAME AND NORMALLY THE NUMBER ON THE IC STARTS WITH "STR *****" SWAPING THE TWO AROUND WOULD PROVE THAT YOU GOT A PROBLEM ON ONE OF THEM,THEN JUST GET 2 NEW IC'C THE SYMPTOM THAT YOU ARE DESCRYBING IS MOST LIKELY THE IC'S HOPE THIS HELPS IGNATIUS ,SOUTH AFRICA TV REPAIR ENGINEER
Feb 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
270 people viewed this question
Jerry Greenberg
Jerry Greenberg
