Question about Creative Labs Zen MicroPhoto MP3 Player
Pictures of the Hole?
Hi do you have pictures and step by step procedures for this cmment. thanks
Remove the sticker. There's some holes in the cover, can you see the disk and the read/ write shaft? Insert a piece of wire or anything that can be used to move the shaft a little, again be very careful. AVOID SCRATCHING THE DISK OR, Move it to the right. If you're lucky to have just a jammed or stucked shaft, then you just save bucks. Replace everything and test your player.
    President:
  • 4,402 Answers
Http://repair4player.org/disassembly_creative.html
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
How do I set the ignition timing on my 1988 GMC S15 2.5L
Best bet, go to your local parts store and pick up a haynes manual, but i can offer my advice if you dont want to do that, first make sure your ignition parts are all good, coil cap rotor, then make sure your firing order is correct, (again haynes manual would be helpful,) then if that fails loosen the distribitor enough you can turn it but not loose enough it would turn on its own, bring your number one cyilinder up to TDC (TOP DEAD CENTER) <(the top of the compression stroke, you do this by getting a buddy to help you, remove the coil wire take the number one spark plug out and USE ONLY YOUR FINGER, cover the hole and have your buddy bump the key untill the compression blows your finger out of the hole, then verify the rotor under the distributor cap is pointed at the number one plug wire on the cap. Again the haynes manual would be a great investment as it explains all this in detail and even has pictures too. good luck and let me know if that helped
Mar 23, 2013 | Cars & Trucks
Tip
How to take apart a wii
Disassembling the Wii<br />Method : Taking it Apart<br /><br />There are plenty of reasons to take apart a wii, whatever your case may be here's a guide to doing it.<br />REQUIRED TOOLS AND ITEMS<br /><br /> * A Nintendo Wii ( of course )<br /> * A Tri-wing screwdriver Size 3 (please save us all the trouble and don't try and use a flathead)<br /> o This NEEDS to have a long shaft. There is a part of the wii that has recessed screws.<br /> * A mini Phillips screwdriver<br /> * A small plate or container ( to hold the screws in )<br /> * A couple pieces of tape ( use the tape to keep track of what screws belong to part of the wii)<br /> * Soft Working surface ( the wii scratches very easily )<br /> * A razor blade and a pair of tweezers will help remove items<br /><br />Step 1. Removing the Battery<br /><br /> <br /> * Remove it and pull the battery tray<br /><br /><br />Step 2. Removing 5 screws /w plastic covers<br /><br /> * When the battery was removed it revealed 1 screw. There are four more hidden underneath plastic stickers and rubber feet. Refer to the picture for their locations<br /> * Peel up the plastic stickers with a razor and pull it away with a tweezers. (place the stickers neatly away from your working area if you plan on putting them back on. )<br /> * Remove the screws ( fix the 5 screws to a single piece of scotch tape and put it in your container. )<br /> * For reference the black screw is the one on the top left, the two longer screws are located on the bottom and the shorter ones on the top.<br /> * This is important to remember because you don't want to put the screws in the wrong holes when reassembling the unit.<br /><br /><br />Step 3. Removing Rubber Feet and removing screws<br /><br /> * Position the wii like in the picture. ( use the notch as a guide )<br /> * There are 2 rubber feet on top and 2 plastic stickers on the bottom that you need to remove. ( do not remove the rubber feet on the bottom. Not necessary )<br /> * Remove the screws and fix them to a second piece of tape.<br /> * Take note that the two black screws go into the faceplate/bottom and the two silver ones go into the top/recessed holes.<br /><br /><br /><br />Step 4. Removing GameCube port covers and screws<br /><br /> * There is a section of the wii that houses the ports for the Gamecube accessories. The 2 covers to this section will flip open and easily detach. If you look there's a sticker on the inside depicting how to remove the covers. They snap off with light pressure. Remove them now.<br /> * Now remove the 3 black screws here and attach them to a 3rd piece of tape. Notice that the screw closest the front/face of the wii is the longest of the 3 screws.<br /><br /><br />Step 5. Removing the face and detaching the cable<br /><br /> * Now position the wii with the face upwards with the dvd tray on the bottom.<br /> * Flip the wii face upwards and away from you SLOWLY and look for the connection marked in the picture.<br /> * Use a flathead of tweezers to pull the WHITE connector out of the socket.<br /> * Set aside the face plate in a safe location.<br /><br />disassemblin the wii image<br /><br /><br /><br />Step 6. Removing the GameCube black cover and screws<br /><br /> * The black covering you saw earlier should lift out easily now. (Although it only goes one way)<br /> * Remove the 4 screws and attach them to a 4th piece of tape and set them aside.<br /> * If the position of the wii is like in the picture then the top screws are tri-wing and the bottoms screws are Phillips. <br /><br /><br /><br /> <br /><br /><br />Step 7. Opening the Wii up and removing 4 screws<br /><br /> * Position the wii with the notch on the bottom right.<br /> * Lift the right side of the wii up and the cover should detach<br /> * Flip the cover over to the left<br /> * The heat sink may or may not come with the cover ( if not just remove it )<br /> * Remove the 4 screws marked in the picture. Fix them to a 5th piece of tape. (although these screws are much different than the rest you've encountered.)<br /><br /><br />Step 8. Disassembling DVDROM drive<br /><br /> * Be extremely careful with this step. Slowly flip the top portion of the drive like in the picture. Notice how short those wires are?<br /> * Remove the White connection first. It's similar to the one earlier on the face of the wii<br /> o TAKE YOUR TIME ON THIS STEP<br /> * Now the thicker cable is removed by flipping the brown plastic tab upwards<br /> o The cable will just slide out now<br /><br />Step 9. Do what you need to do!<br /><br /> * You're all done! Enjoy!<br /> * The marked area is an ideal spot for a modchip<br /><br />o Not that we condone the use of modchips for illegal activities or anything. <br /><br /><br /> i could not upload the pictures with this post so please email me if you need the pictures on the removal of the, hopefully you should be able to understand from the instructions above but if you get stuck just drop me a message on<br />pauldonp@msn.com<br />
on Nov 24, 2010 | Video Game Consoles & Games
Snapper line trimmer the pull string broke how do we change it
It is always a good idea to take pictures of each removal step to make reassembly easier.
Remove cover on the pull rope housing. Locate the flywheel which the pull cord wraps around. Remove screws or bolts that attach flywheel on the housing unit. Caution, be careful on recoil spring position. Locate hole on flywheel (side view) in which the original cord was feed through. Feed replacement into hole and tie a single knot. Reattach assembly.
These are the instrument you will used:
  • Screwdriver
  • Rag
  • Metal brush
  • Detergent
  • Gas
  • Fuel line
  • Fuel filter
Thanks for contacting Fixya.
T
r
Jul 09, 2010 | Garden
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
How do I access headlight bulbs on a 2009 Dodge Ram 1500?
I hope describes correctly the detail procedures for replacing 2009 Dodge RAM 1500 Headlight Bulb.
- First, open the hood; Disconnect the negative battery cable;
- Remove the four grille attachment bolts;
- Remove the grille;
- Remove the two headlamp assembly attachment bolts;
- Then reach into the front wheel house ahead of the front wheel to unsnap and lift the cover over the access hole in the front of the wheel house splash shield.
- Access to the bulb retainer can be gained through the wheel liner hole (see picture).
After that reach through the access hole to access the rear lamp retainer and remove headlamp assembly (see below picture).
Disconnect electrical connectors, and replace the bulbs.
Good luck (remember rated this help).
Nov 26, 2009 | 2007 Dodge Ram Truck
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
Removing printheads on HP C6180
When the cover is open there's a cover on the right side just over the printheads. You need a flat tip screwdriver to lift the lid, but it allows you to remove the printheads.
Aug 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
How to refill the 920 XL ink?
are you talking about the 920xl or some other cartridge , any more specific instructions i pealed the sticker back and there is one hole and a series of s's that looks like its where the body of the cartridge is put together. does this thing have a bladder or tank inside and how many ml's or cc's does it hold.
Jun 29, 2009 | Office Equipment & Supplies
Upgrade main memory
the back cover has 4 main screws after u have removed them the hole back cover is filled with latches, its a real pain to remove but u can do it. i suggest using clock work screwdrivers to lift the back cover. don't be ruff but dont just do it lightly.
good luck
Oct 26, 2008 | Acer Aspire 5315 Notebook
I dont know which hole to refill 32 cartridge on lexmark x5450..it looks hard???
You have to remove the sticker on the front of the cartridge. Under the sticker (upper left under the sticker when looking at it correctly) is a very small hole. Put you needle into that hole, which you might have to rout open a bit, for injecting your ink. I did it and it works great. Just be sure and put a piece of tape or sticker of some sort over the hole after filling.
Jul 27, 2008 | Office Equipment & Supplies
Creative Labs Zen MicroPhoto MP3 Player Logo
130 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
