Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Wireless wont broadcast
The modem won't broadcast the wireless signal and we're not sure at all how to get it to work... (we reset it and the wireless light just plain wont come on, ust the first three, the power one and then two others).. i know this is vague but any suggestions?
    Scholar:
  • 89 Answers
Hello, Depending on router brand but the Default Address is 192.168.1.1.....enter this in the address window of browser. You'll be prompted to enter user name and or password(You also need to change User name and Password). Default for both is "admin". From there you'll need to click on the wireless settings and check the box for "Enable wireless router radio" and "Enable SSID Broadcast". Be sure to Check "Enable Wireless security" for WEP security(I also use a 64 bit key). Hopefully this will help.
Posted on Mar 10, 2008
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
SMC2804WBR router: The lights are on but nobody's home.
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Nov 17, 2009 | SMC Barricade g SMC2804WBR Wireless Router
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
Mar 18, 2009 | Linksys WCG200 Router
Wireless light
Is the Wireless signal turned on within your 2Wire options?
Try turning it on.
Aug 23, 2008 | 2wire (1000-000057-000) Modem
ROUTER SIMPLY WONT WORK WIRELESSLY AT ALL
firmware reflash:
if the router's SSID is not broadcasted even though it is on "SSID Broadcast enabled" under the wireless settings, you may need to reflash the router's firmware if a HARD RESET did not work.
Hard reset:
this is pressing the reset button on the router for 25 seconds, unplug and replug the power cord while reset is still pushed, then let go of the reset button once the power is plugged back in.
Firmware upgrade:
Click here to get the steps needed to be done.
if this still did not work, you may want to contact Linksys tech support at 1-800-546-5797 for further troubleshooting or an RMA depending on the status of the device.
Aug 18, 2008 | Linksys (WRT54GC) Router
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
194 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
