Question about HP Pavilion F1703 17" LCD Monitor
Monitor repair I am from India and needs repairing for my monitor 17" HP make 2002. The power Unit in the said monitor is burnt and needs replacement or repair. plaese help. Thanks, Yours faitfully, Anilbhai Desai email: anil49@gmail.com
    Sergeant:
  • 349 Answers
Look in your local paper for monitor repairer,
but as the cost of a new monitors has come down so much ,i would consider a new purchase as the refresh rates and picture quality are far better now than when your monitor was produced,also second hand prices are very low .
good luck
Terry
Posted on Mar 10, 2008
I have a hpl1706 monitor,it has a problem of starting,when i switch it on the power led starts blinking all the time but the monitor does not does not start at all,i am little good at repair work so i was...
there are 3 capacitor in the power supply section on the circuit board, you will have to change all 3 capacitors the value of the 3 capacitor are 1000uf/10v and all 3 are soldered at one location, you need not search for those capacitors, if you see the component side of the board you will find those 3 capacitors either difused or burnt out.
Sep 06, 2011 | HP L1706 17" LCD Monitor
Tip
Dell Monitor Repair
How to fix a Dell Monitor that just flashes the power light or also flashes the screen on and off very fast. In this video I repair my E178FPb with this problem. In my video, I show how to take it apart, recognize the problem, and replace the parts. I ordered the parts off Mouser and it only cost around $6 with shipping. The problem was visual and I found 2 electrolytic capacitors bulging and a ceramic capacitor burnt. Mouser Electronics Electronic Components Distributor
on Jun 10, 2015 | Dell E178FP 17 inch LCD Monitor
Hp mini monitor broken. Replacement possible ??? Please inform where in India. I live in Eastern Chattisgarh. s/n CNU9040W3G is the identifying number of the unit. Dr. B. E. Getter. email: ...
Sir,
The cost of replacing monitor will be as good as buying a new laptop.Replacement can be done at hp reseller. You can call Hp for exact location of reseller or price of repair
1800112267 (BSNL/MTNL lines within India), 30306363, 011 26388000.Monday to Friday, 9:00am to 6:00pm
Thankyou
Sep 07, 2010 | HP Pavilion dv6000z Notebook
Emachines monitor e15tr model 568 wont come on
Try to connect the monitor to the VGA-output port of some other desktop or notebook computer. If it does not work, then it needs repair or replacement. If the monitor still under warranty:
* standard 1-year warranty from Gateway
* extended warranty that you may have purchased from Gateway
* extended warranty that some credit-cards offer for items purchased with that card
* extended warranty that you may have purchased from the retailer
If not, it's probably cheaper to replace a 15" or 17" or 19" monitor
that it would be to try to repair it.
Nov 27, 2009 | E-Machines eMachines Monitor E15T4
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 19, 2009 | HP Pavilion F1703 17" LCD Monitor
No Power
Hi...there,
No, power.. Could one things, your backlight inverter are burnt out. Need to replaced a new inverter or repaired it.
Oct 11, 2008 | Dell E173FP 17" LCD Monitor
Repair
Good luck finding a replacement FBT; support for CRT monitors is fading fast.
That transformer is probably not the only thing that failed, the horizontal output transistor that drives it is likely bad too.
If you want to repair it, I also recommend you check any bipolar capacitor in that section as it may also have failed.
Aug 24, 2008 | LG Studioworks 563N 15" CRT Monitor
HP L1702 lcd monitor power on then goes off
There are 8 caps that need to be replaced on these monitors.
2x1000uf 16v
6x470uf 10v
It is an easy repair if you know how to do it. If not, then your local TV repair man can do it fairly cheaply and quickly.
Mar 31, 2008 | HP L1702 17" LCD Monitor
Monitor
The power supply in this monitor has probably failed, but since HP doesn't stock spare parts for their monitors you will probably need to replace the whole monitor. HP only does full unit replacements on their LCD monitor range.
HP also doesn't provide any electronic schematics so getting it repaired will be difficult.
Feb 11, 2008 | Compaq FS7600 17" Flat Glass Monitor
HP Pavilion F1703 17" LCD Monitor Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
