Question about Apex Digital AVL2076 20 in. EDTV-Ready LCD Television
How to turn off the SAP - Secondary Audio Program
I have the Apex AVL2076 digital TV but without the original remote and from the TV on-screen menu there is ** provision to turn off the SAP. I purchased an Universal TV Remote and there is ** button to turn off the MTS/SAP feature. Is there any other way I can turn off the SAP feature without buying the replacement remote from Apex, which cost $27 plus $8 shipping?
Thanks,
John
  • Mary Perry Apr 05, 2008
    I have a Apex Digital TV and want to connect a Bose 3.2.1. system and then use the remote from Bose to run both the TV and the Bose. I also have a Panasonic VHS-DVR to be connected. Can you help me, so I can understand the connections of Y Pb P, etc on the tv. I have to be able to use the Bose Remote. I have tried to set it up, but the remote still won't let me use the 'change channel' button, so I must have something connected wrong.
SOURCE: Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Posted on May 01, 2007
SOURCE: Replacement Power Supply Cord for Apex Digital AVL2076
The orignal power cord went out and our Toshiba laptop has a similar cord. The cord for my lap will work with the TV. But i dont know for how long. The tv is for my 5 yr old and we have never used it more than 4-8 hrs straight. You can purchase the cord for about $65 the model# A135-S2256. I hope this helps. I was actually looking for the orignal cord and i have been running into the same problem. So it looks like i'm going to purchase the Toshiba cord too.
Posted on Dec 14, 2008
  • 155 Answers
SOURCE: philips universal remote codes
Hi Troysingleto. The code can depend on what model of URC you have. According to a site I found by Googling, the code for Apex TVs on one common URC from Philips is 044. Here are the steps to input it directly:
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, DVD, etc). The red indicator blinks, then stays lit.
3. Enter the 3 digit code (044) . Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
If that code does not work, you can still find the code using this manual procedure first posted on FixYa by cptnkirk4064:
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired code button (TV, VCR, etc). The red indicator light should blink once.
4.Press the "Channel Up" button repeatedly (up to 300 times) until thedevice to be controlled changes channel. The red indicator light shouldblink off with each button press. If you accidentally overshoot therequired code, press the "Channel Down" button to backtrack through thelibrary until the device changes channel. Pressing "Channel Up" changesdirection again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4.To find the first digit for the code stored under the mode key pressedin "Step 2" press each numeric key from 1-9 in turn. When the redindicator light blinks off, the number you pressed is the first digitfor the code you are searching for.
5. To find the second digit,repeat "Step 4," this time when the red indicator light blinks off,this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Once I find out the code for my TV or DVD player, I write it on a small piece of paper (make sure to note which unit code is for!) and tape it to the inside of the lid to the battery compartment for future reference.
Best of luck!
Posted on Feb 14, 2009
  • 125 Answers
SOURCE: can i use the apex avl2076 for a computer monitor?
Yes, you can but you need a VGA cable to go from your laptop/PC. If your Laptop/PC has a DVI video connector, then you also need to get a DVI to VGA adaptor. The manual below will explain how to connect your TV to a PC.
http://www.retrevo.com/s/Apex-AVL-2076-TVs-review-manual/id/524ci557/t/1-2/
Posted on May 02, 2009
SOURCE: need remote control for my Apex Digital DVD player (model 1110W)
DVD remotes typically have 2 sets of up and down arrows for such things. Make sure the remote you purchase is meant for dvd players.
There really isn't anywhere to search for what remote would work perfect for you other than some very costly ones. So I can't really point you in the direction of a make or model.
You can also Email Apex Support and ask them for a replacment remote. It will cost you but no more than a normal remote and its made for your dvd player.
Thank you for stopping by Fixya!
Posted on May 20, 2009
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
What features does a apex tv gt3215 have?
GENERAL
  • TV typeCRT TV
  • Screen size
    32 in
  • Power Consumption Operational
    150 Watt
  • Timer Functions
    Sleep, wake
  • Video Interface
    Composite, S-Video
  • Manufacturer
    Apex Digital, Inc.
FEATURES
  • TV features
    auto volume adjustment
VIDEO
  • Technology
    CRT
  • Aspect ratio
    4:3
TV TUNER
  • TV tuner presence
    Yes
  • Analog TV tuner
    NTSC
  • Reception System
    NTSC-M
  • Secondary Audio Programme (SAP)
    Yes
  • Secondary Audio Program (SAP)
    Yes
  • Channel Coverage
    VHF:2-13, UHF:14-69, Cable:1-125
  • Stereo Reception System
    MTS
AUDIO
  • Speaker(s)
    2 x main channel speaker - built-in - 5 Watt
  • Output Power / Total
    10 Watt
  • Audio Controls
    sound mode
CONNECTIVITY
  • Video interface
    composite
REMOTE CONTROL
  • Type
    universal remote control
  • Supported Devices
    DVD player
CONVENIENCE
  • Closed Caption Capability
    Yes
  • Parental Channel Lock
    Yes
  • V-Chip Control
    Yes
  • Menu language
    Spanish
MANUFACTURER WARRANTY
  • Service & support
    1 year warranty
POWER
  • Nominal Voltage
    AC 120 V
  • Power consumption operational
    150 Watt
DIMENSIONS & WEIGHT
  • Weight
    156.5 lbs
DIMENSIONS & WEIGHT (SHIPPING)
  • Width
    38.7 in
  • Depth
    29.2 in
  • Height
    30.5 in
  • Width (Shipping)
    38.7 in
GENERAL
  • Manufacturer
    Apex Digital, Inc.
Mar 08, 2014 | Televison & Video
Apex Tube tv
check your screen menu and check screen size should say normal, wide screen and cneima . change to a smaller screen should bring everything in line
Feb 08, 2013 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Turn off sap
SAP is secondary audio program---It can be turned off or on in a possible two places.
On the set in the audio menu (most original remotes have a SAP or MTS button for this but in the set menu it can also be adjusted on or off.
If you are using a cable or Sat box or even a receiver the box will have the SAME feature built into it--yes Sap can come from a cable box or sat or receiver.
May 24, 2012 | Sansui 32" TV
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
I need the code for an Apex digital model AVL2076 so I can program my Allforone remote
Buy a Remote Control 5-Funct Philips is universal, the manual tells you how to use it. I have one and it works to perfection, buy it at any establishment of PriceSmart or Cosco. you can visit the websites of these establishments.
Oct 30, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Some channel has audio and other not why?
Most common cause: Look in the menus for something called SAP or Second Audio Program. This option should be turned off. Make sure that the TV is in the MTS or equivelent mode. Jerry G.
Jun 07, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Sound
The SAP must be turned off and you must have the original remote apparently. I would do a search for Orion customer support and get a remote.
Feb 10, 2008 | Orion STV2763 27" TV
Apex Digital AVL2076 20 in. EDTV-Ready LCD Television Logo
615 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
