Question about Microsoft Windows XP Professional
Cannot open drive
Hi, I cannot open my drive c:, every time i click my drive C: i get an open with prompt. What should i do.
  • 24 Answers
I would agree with solution 1. it is probobly a virus. Ewido or avg would work, but in my opinion, norton stinks. Run one of the antiviruses and that should take care of it.
Posted on Mar 24, 2008
    Problem Solver:
Its a virus. just nuinstall any other anti virus software. then install avast anti virus. then restart d pc. tis problem is mainly due to autorun.inf . hence while booting d software wil scan d system. then u delete the autorun file by pressing 1 key. ur problem wil be solved
Posted on Mar 21, 2008
    Sergeant:
    Champion:
  • 277 Answers
Your pc had a virus infected. do not click the drive c, use windows explorer or right click the mouse and explore it..
Posted on Mar 10, 2008
    Problem Solver:
  • 21 Answers
Your context menu (the menu when you right-click eg on the C: drive is most probably corrupt or set wrong (the dafault action is set to Open With ... and it should be "Open" - as an alternative till you fix it, just right-click on the c: drive and select Open from the drop-down menu
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
Oct 20, 2016 | Microsoft Computers & Internet
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
How do I transfer data from SanDisk onto my computer?
connect your flash drive with your computer . then open the my computer . On my computer find your flsh drive then open your flash drive and now copy the documents in the flash drive now open another my computer option then open any of your local disks like local disc c or d or d then now press the following keys at the same time ctrl+v. if still having problem reply me i will help you
Jun 18, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to format a new seagate external hard drive
Hi josernld
Formatting your drive for Windows Vista
STEP 1: Open Computer Management like this:
  1. Right-click on the Computer icon.
  2. Click Manage.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
STEP 2: In the pane on the left, under Storage, click Disk Management.
STEP 3: Right-click the drive that you want to format-be sure it's the correct drive-then click Format
STEP 4: To format with the default settings, in the Format dialog box, click OK, and then click OK again.
Formatting your drive for Windows XP STEP 1: Open Disk Management like this:
  1. Right-click on the My Computer icon.
  2. Click Manage.
  3. In the pane on the left, under Storage, click Disk Management.
STEP 2: Right-click on the drive you want to format. Be sure it's the correct drive.
STEP 3: If you want, you can type a name for the drive in the Volume Label box. This is an optional step.
STEP 4: Click the file system that you want to use in the File System box. You can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
Note: Before changing the default allocation unit size please refer to Microsoft Knowledge Base Article 314878.
STEP 5: Click OK. When you're prompted to format the drive, click OK again.
Formatting your drive for a Mac STEP 1: Open Disk Utility like this:
  1. Click Finder.
  2. Click Applications.
  3. Click Utilities.
  4. Click Disk Utility.
STEP 2: Select the drive you want to format. Be sure it's the correct drive.
STEP 3: Go to the Partition tab.
STEP 4: Click on the Current Volume Scheme drop-down menu and select One (1) partition.
STEP 5: Click Options. From the Partition Schemes provided:
  • Click on the GUID Partition Table radio button.
    --OR--
  • Click on the Apple Partition Map radio button.
STEP 6: Click OK. Select other options as desired (e.g., Volume Name, Format, etc).
STEP 7: Click Apply. The Partition Disk screen opens.
STEP 8: Click Partition. At this point, the volume dismounts from the desktop and the drive is partitioned and formatted.
Note: When Volumes are created, Time Machine may open, asking if you would like to use the volume for backups. Click Cancel to proceed.
STEP 9: When finished, select the Disk Utility from the Apple Menu and choose Quit Disk Utility.
Feb 17, 2011 | Seagate Computers & Internet
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
Nothing is openning
Thank you for using FIXYA!
Does all your CDs not working when you insert them on your CDROM drive? There is a possibility that you CRRom drive's lens is failing. You can try cleaning it with a lens cleaner Or try this steps below.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
If this steps did not fix the problem i would suggest buy a new one to save you the hassle and time.
Sincerely,
stif_nec
May 22, 2010 | LG CRD 8522B Internal 52x CD-ROM Drive
When i use an external drive(pen drive) and open this drive from my coomputer, it opens in a new window
Stape:: 1 Scan Your Pc
Stape ::2 right Click in your Property
And Autoplay Tab
Select prompt to ech time to chose in action
apply
ok
enjoy
Aug 18, 2009 | Computers & Internet
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
DVD OR CD not drive by CD-ROM
Option One:
To fix it, open “My Computer”, or “Windows Explorer”, find the drive icon for your CD/DVD player/burner and right-click on it. When the popup menu opens, choose, “Properties”. Click on the “Auto Play” tab. Click on “Select an Action to Perform”. Click on the “Restore Defaults” button and click on the “Apply” button. Then click on “Prompt me each time to choose an action” and click on the “Apply” button again. (Note: If you want it to open in a particular program each time you put in your music CD, instead of clicking on “Prompt me…” choose the program you want it to open each time you put in your CD. Now click on “Apply” and “OK” and restart your computer. Now put in a music CD and see if it works as it should.
May 30, 2009 | Acer Aspire4720 14.1-inch Notebook PC PC...
My drives r not opening by double click
That usually happen when your computer was infected by virus, have it scann using different scanner not that is found in your computer cause that cannot detect the virus.
Thanks.
Nov 22, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
113 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
