Kenmore 80 series
HELP! I have a Kenmore 80 series washing machine. It finished all the washing and everything, but it won't drain and spin. It does not leak and it doesn't make any weird noises. I checked the power and try turning it on again, but it just stopped moving. What should I do?
  • 5 more comments
  • Caile Mar 10, 2008
    I already took out all the cloths, but the washer simply don't drain.
    at least i want to figure out how to drain it first before i could do anything else. if i have a clogged line or bad pump, how should i check it?
    it drained fine on the first cycle, but half way thru the second rinse, it stops.
    apparently nothing is working at the moment. i've tried turning it on or off at different cycle, but it doesn't start anywhere. when i say it draiend at the first cycle, was before this whole thing happens.
    i've ***** fixed these before.
    or should i just consult a mechanic?
    thanks for your help.
    Genius:
  • 3,587 Answers
You may need to take some clothes out, since it might consider the situation an overload..try that first and see if it helps
Posted on Mar 10, 2008
  • 6 more comments
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    ok..thanks..then you either have a clogged line, or a bad pump..you inclined to check into this yourself?
  • Patrick Michaels
    the clogged lines are easy..shut off water, and unhook them, from each end, then blow air inside of them, or run them from hose in yard.
    the pump is another issue...you'll need to 'drop' it from underneath(propping up the machine is needed) and then you'll find out if it's free or frozen.
    other possibility is that your control board is shot, and even if pump is fine, lines are clear, that could be ignoring it's sequence, and stopping the cycle
    does it drain in any of the cycles at all?
  • Patrick Michaels
    ahh..that's important..then you can look to the control board..does it work all the way through on any cycle?
  • Patrick Michaels
    ok..sounds like the control board is off duty..do you do this stuff, or are you a call the maytag kind of person?
  • Patrick Michaels
    ok..just asking..you'll need to get a new board online...
  • Patrick Michaels
    that would be an effective strategy..local washing machine folk are fine..the parts can get a little weird though
  • Patrick Michaels
    wish it were different..you're on the right path. so stick with it.
  • Patrick Michaels
    thanks for using Fixya
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
