Question about Canon S900 InkJet Printer
Now got a reset problem...
Had the ink absorber problem on my S820. Tried to fix it by not actually cleaning the absorber, just going through the reset procedure (I guess this may have been a bad idea?). Now, when I turn the printer on it makes all the moving around noise and then turns itself off. I can't go into service mode as it just makes the noises and turns off when I release the power button at the end of the sequence. Any ideas how I can get out of this one???
Cheers,
Steve
  • 4,041 Answers
Hi ok
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. Service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Posted on Feb 13, 2010
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
My Canon MP210 printer [ USB001 ] said the Ink absorber is Full contact the service center. Guess what, the service center just gave information. I need to know if will be able to fix or will...
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. There are actually two absorber pads located on the right side of the printer, under the
ink cartridges when the carrier is in the home position.
Accessing the pads and remove them for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezers and extra cloth for some ink spillage. Using the tweezers, lift up the pads sitting on the rubber retainer. The pads can be easily clean by placing them under running water. Use warm water to remove the ink from the pads. Dry the pads and reinstall them. Same procedure if you are installing new pads.
However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
7.
Please rate this solution. Let me know if you have any more questions. Thanks.
May 30, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
1. Click Reset Main to reset the waste ink counter and
2.
Happy printing.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
Mp130 waste ink absorber almost full. how to fix?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer
and start printing again
1. Turn on the printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Do this as many times if the first attempt didn't work until it fully reset.
Aug 08, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Ink absorber
actually ink absorber is full means you printer inside got small pieces towel
to absorb ink. but Canon PIXMA printers display an error when a certain internal counter suggests that the ink absorber may be full. If you've done a lot of printing, the ink absorber may actually be full and you might need to have it cleaned or replaced to ensure the best printing quality. However, if you haven't printed that much or you have and you just need to print something right this minute, there is a way to reset the counter and stop the error from showing up again
please try go to this website :
http://ij-forum.blogspot.com/2008/09/how-to-reset-ink-level-of-fine.html
the you go left hand side download General Tools (EEPROM Resetter) Collection and install on you cpu.
after download remember to turn on printer before install it.then go to Reset ink counter by clicking Reset main on waste ink counter menu
try this if can't i think you need send to shop for technician to open it and clearning for you....
Aug 17, 2009 | Canon PIXMA iP1600 Printer
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Canon S900 InkJet Printer Logo
111 people viewed this question
old marine
old marine
