Question about MSI K8T Master2-FAR Motherboard
8 GB RAM problems
I have K8T MS 9130 motherboard and have been operating with 4 GB of ram (4 X 1). The processors are 2 X 246 Opterons. I tried upgrading the RAM to 8 GB and the machine recognises the RAM but will not boot into windows. The Windows logo comes up for about 6 seconds, then blue screens and crashes. I have two drives, the first a SATA (raptor) drive and the second an IDE. It will also run with 2 of the 2 GB sticks but not all 4.Any clues???
  • 9 more comments
  • thrifty2 Mar 10, 2008
    Sorry I did not specify that I was running Windows XP 64
    Sorry I did not specify I was using XP 64
    Its been running 64 bit software since new and had ** problems so far. The application (FEA) is very CPU intensive and an additional 4 GB of RAM would really reduce the I/O and push the CPU's a bit harder.
    All memory is matched. I bought a total of 16 GB, 8 for one machine (which worked fine) and anther 8 for this one.
    The board has 4 slots operating in pairs.
    Currently I am operating with 2 X 2GB sticks. I have swapped these for the other 2 GB sticks and they work fine also.
    Should I try adding the 2 X 1 GB sticks (giving a total of 6 GB) first?
    I suspect the problem is related to the MB not handling the full 8 GB. When going into the BIOS it is all good and says the full 8 GB is there and OK. The probelm seems to arise when booting XP 64. Maybe there is a conflict with the SATA C: drive!!
    What is the allocation drill?? What level do you do that at? Not at BIOS I presume.
    Bailed out eh!!
    The link does not tell me how to turn on
    IMAGE_FILE_LARGE_ADDRESS_AWARE
    Is this in the regedit?
  • thrifty2 Mar 11, 2008
    I am skeptical, but will start with a new HDD and see how it goes in a couple of days. I reckon the mother board is not up to it!!
  • thrifty2 Mar 13, 2008
    Would not install!! It just hung at the windows setup menu and would not progress. I think that there is a conflict. The RAM is 400 MHz FSB but I do not think the Opteron processor will support more than 4 GB of RAM at this speed. The MB BIOS will not allow me to derate the memory to a lower speed. It's either that or a clash with the SATA drive.
    This is not worth the grief!!
  • thrifty2 Mar 14, 2008
    The documentation was inconsistent. Some specs say 4GB and some 8GB. The manual shipped with the MB says 8!!
    When it booted to BIOS all the RAM was there.
    Genius:
  • 3,587 Answers
Yeppers..windows has a limit on how much ram you can load into it..you'll need to segment that ram, and allocate it through bios, to each uP so that each see not more than 5 gig....interesting huh?
Posted on Mar 10, 2008
  • 13 more comments
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    ekse..good point..the on board devices also MUST be compliant with 64 bit standards, and there just aren't that many boards out there in 64 bit land, either..
    maybe you might consider the virtual memory watusi, eh?
  • Patrick Michaels
    here's a nice treatment on that very same issue, for Vista, etc.
  • Patrick Michaels
    well..xp 64 is fine. are the chipsets compatible with 64 bit all the way down the line? sometimes parts of them are, like video chips
  • Patrick Michaels
    from this description, the memory MUST be matched and of same type is that the case?
    click here for more on this board
  • Patrick Michaels
    got it..so the h/w is good..then it's MSoft's stated inability to handle that much memory in allocation mode. There's not simple answer.
    here's a thought..can you step up the memory, in 1 gig steps, so that it will configure, like an upgrade approach?
  • Patrick Michaels
    i suppose swapping out the memory from machine one to two has been done? i've seen more fickle situations in my over 30 years of working with MSoft
  • Patrick Michaels
    yes..try the smaller memory and see if the windows fires up..if it does, then you'll need to do the memory allocation drill, and hope(cross your fingers) that the extra 2 gig will work..
  • Patrick Michaels
    nope.not with 64k bits Msoft..for the advanced folk, there are special memory allocation applications, that are open source..looking on google will show you, or download.com
    I'm only giving this a 50/50 shot, and I'm quite surprised that the other machine is running
  • Patrick Michaels
    here's a nice video that spells it all out..
  • Patrick Michaels
    nope..still online here in hawaii...what's the new information>?
  • Patrick Michaels
    right from MSoft help and support on win xp 64 memory allocation. as I mentioned, this is not for the faint of heart.
  • Patrick Michaels
    I'd highly recommend that you have someone that has done this once or twice tune your machines..
    thanks for using fixya
  • Patrick Michaels
    I'm not that familiar with this aspect. I'd recommend you be really careful here..
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    hmmm..now, that would be interesting..the o/s is on the drive, granted, but the rest of the handling is on the board..flips a coin to see who gets the fixya and dinero on this one. I'm tapped out, amigo..
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    yeppers..you got it..welcome to the illusory HIGH end of the MSoft kingdom, where Ram dies, and hard drives cry. You going to finish this one out. Seems that either of us deserve this to close, one way or another..
  • MSI Master
  • 13,433 Answers
Windows doesnt like hardware changes. and specially if your useing a 32bit windows it doesnt support more than 3.0-9GB of ram. you need 64bit windows to work on 4GB or more.
  • 6 more comments
  • Ekse Mar 10, 2008
    Windows doesnt like memory changes like that. Only option I see is reinstalling your windows, that would solve the problem.
    and do post us what the bluescreens say. the codes mainly.
  • Ekse Mar 10, 2008
    Note to everyone: The motherboard and cpu have to support 64bit, the os wouldnt install if it wasnt so.
  • Ekse Mar 10, 2008
    it really is that simple, just reinstall windows. I've had these problems for years. Oh get back to me if it doesnt work. Also a good idea might be to install it on a empty hard drive so you dont loose any of your data incase it doesnt work.
  • Ekse Mar 11, 2008
    Tell me how it goes after a fresh install.
  • Ekse Mar 13, 2008
    hey, your motherboard doesnt support more than 4gb of ram!
    http://www.msicomputer.com/product/p_spe...
    144-bit DDR at 200, 266, 333MHz, 400MHz.
    Supports DIMM sizes from 64MB (128Mb x 16 DRAMs) to 2GB on each DIMM slot.
    Supports 4 DDR DIMMs upto 4GB (Registered Memory only)
    Supports interleaving memory within DIMMs.
    ChipKill ECC allows continuous correction of 4-bit errors in a failed x 4 memory device.
    For Single AMD® Athlon-64 FX 51 series, it will support Registered Memory up to DDR 400
    For Single orDual AMD® Opteron Series, it will support Registered Memory up to DDR 333
  • Ekse Mar 14, 2008
    Try another operateing system. But everything still points to too much memory.
  • Ekse Mar 14, 2008
  • Ekse Mar 14, 2008
    "The motherboard has to support "memory remapping". On some boards, this feature can be switched on or off in the BIOS, but it can be hard to figure out where the feature can be found, and even what it is called. In some cases, it is activated together with some of the CPU features. If in doubt, your best bet is checking your motherboard's manual."
More than 2gb
Max for this model is 3 gb running at 333mhz speed, if you have 400 speed you can only run 2 gb ram max. and for 3 gb all memory must be double sided type of Ram
Mar 08, 2012 | MSI K8T Neo-FIS2R 800MHz FSB VIA K8T800...
Problems with new ram
This = NO
The Foxconn P4M800P7MB-RS2H motherboard supports ram memory that is either 400MegaHertz, or 533MHz.
You have installed 667MHz ram memory.
http://www.play.com/PC/PCs/4-/3274794/-/Product.html
You also need to watch the Front Side Bus (FSB) of the processor you are using.
Ram memory typically operates at HALF of the FSB of the Processor.
Processor FSB support is 800MHz maximum.
Half of that is 400MHz.
You CAN use 533MHz ram memory, however.
(This is DDR2 Sdram ram memory.
PC2-3200 is DDR2 at 400MHz.
PC2-4200 is DDR2 at 533MHz. (Also known as PC2-4300. Depends on the ram memory manufacturer.
PC2-3200 actually operates at 200MHz. { Max} It is 'Dual Pumped'
PC2-4200 actually operates at 266MHz )
What to do?
Hopefully you saved the carton/s the ram memory came in.
Ship them back, get the ram memory you need.
ALSO;
What is the FSB of the Processor you have installed?
Don't know?
Post back in a Comment as to the model name, and model number.
(Example; Intel Pentium D model 805,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
FSB support is 533MHz
No, you cannot use 533MHz ram memory. { PC2-4200 }
PC2-3200 is the max.
Pentium D model 820 for example, you can )
Nov 18, 2011 | E-Machines Computers & Internet
I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
Otherwise, your operating system or hardware problem will occur.
Dec 29, 2010 | Microsoft Computers & Internet
P4vm800m7 motherboard 2.66 ghz processor and 500gb hard disk how much ram required
rsadhashiva,
How much RAM is required is mostly based on what operating system you plan on running, as well as what programs you are using.
The average computer has between 2 to 4 GB (Gigabytes) of RAM, though it isn't unheard of for some higher-end systems to have 8 GB or more.
Hope this helps.
-S
Oct 20, 2010 | Mercury P4VM800M7 Motherboard
I am going to upgrade ram to 1 gb. can i use ddr2 1 gb ram to upgrade .motherboard is microstar model ms-6526 ver: 2 . present ram is ddr1 400 MHz, 512 MB
If your computer has two RAM slots on the motherboard, i would recommend trying it. The computer will run on the 512MB stick alone and just not recognise the other stick. And if it works it works.
I have searced for support documentation and came up with none for the original MS-6526
I run my original version MS-6526 on a 512MB PC2300 (DDR1) and a 512MB PC3200 (DDR1) and it runs just fine for games and videos.
Personally I would recommend trying the DDR2 first and if that fails, return the card and get a DDR1 card. They are expensive, but at least they work.
Oct 08, 2010 | Intel Microstar MS-6526 Pentium 4 ATX...
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
How much ram is suitable for 2666mhz processor
1 gb is ok but if u put more ram is much better.
Jan 17, 2009 | Intel 845GE Motherboard
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
MSI K8T Master2-FAR Motherboard Logo
139 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
